Is it my blower motor or resistors? 86 4Runner
Old 10-26-2008, 05:39 PM
My99's Avatar
Hey all -
Well my truck has been running quite well lately, but tonight I was driving along and the heater kicked off.
Background:
Last year I replaced the resister coils because the fan would only run on low & high. Got all my speeds back so all was well. About 3 months later I turned on the blower and got NO response from any speeds. Somehow I discovered that lightly bumping the fan area would make the unit turn on, and it had nothing to do with the fan speed position.
Fast forward to tonight - The light (and even a bit more than light) tapping on the fan unit did nothing to get it to turn back on.
So I pulled out the resistors, and hooked up the ohm meter. There is resistance across each and every combination of the 4 plugs, but I'm not sure what it is supposed to be.
So what do you all suspect? Resistor pack or has my fan finally given up the ghost?
Old 10-26-2008, 05:43 PM
iamsuperbleeder's Avatar
sounds to me like that motor has finally gave out on ya
abecedarian's Avatar
/me thinks fan.
Old 10-27-2008, 06:52 PM
My99's Avatar
Fan indeed. Picked up a unit at the local auto parts store. Box said VDO, sticker on the unit says Siemens. Who knows.
Tip for those installing - Be sure to keep the rubber seal/gasket off your original fan. I got to experience taking mine off, as it fit's a "tad" loose without it.
Other than that, pretty straight forward. You don't have to remove anything to get to it. The back bolt is a bit of a bear, with minimal room to ratchet.
In other news, I think my fan was still okay, but one of the 2 wires that powers the motors from the plug was pulled off the motor. I wasn't patient enough to try and repair it. The way the motor failed, it seemed like the 22 yr old gal still had some life in her, but the connection just came loose.
Old 10-27-2008, 06:59 PM
thanks for the follow-up.
you now have a fan you can solder back together to use as a spare in about 15 years or so when this 'new' one goes out.
Old 10-27-2008, 07:01 PM
or sell on eBay as "refurbished"
Old 10-27-2008, 07:16 PM
My99's Avatar
I'd gladly ship it to any of you on your dime if you want it. You are welxome to keep as a spare or sell it yourself. Probably isnt worth the cost of shipping, but maybe Matthew would take it off my hands...Otherwise, to the dump, sadly.
Old 10-27-2008, 07:18 PM
won't fit on my 91, but thanks anyway...
abe?
I replaced my resister not too long ago, and have had no issues... knock on wood...
Old 10-27-2008, 08:09 PM
toyNG's Avatar
I experienced almost the exact same thing earlier this year. Resistor went out, and about 3 months later, the fan went out. Is this coincidence? Or is this a typical sequence for fan failure? just curious...
Old 10-27-2008, 08:48 PM
I replaced my resister about a month after I got my truck; it was shot when I got the truck. I have yet to have any issues with the motor, and it's almost been 2 years, so probably just coencedence (spelling)
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
AaronM
07-08-2015 07:15 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Is it my blower motor or resistors? 86 4Runner
