loping idle, no power, 14 miles on a fresh rebuild?
Old 01-16-2011, 02:32 PM
az_eaglescout_pilot's Avatar
88 3.0. just got it all installed and buttoned up, drove it for a while, threw code 52, new knock sensor and wire installed now it runs really bad, idle "gallops" i thought it might be timing causing the issues. few questions...the timing is supposed to advance correct? so why when i have the timing light hooked up does the timing not advance? set it at 10* BTDC... the b stands for "behind" TDC or "beyond" TDC? right now with the distributor turned all the way counterclockwise the timing mark is at 15* i have pulled the distributor and moved it one tooth so i could get a little more adjustment but it had no effect, checked the vacuum lines for correct placement twice...could a vacuum line cause the timing to be off?
any help greatly appreciated.
-Jordan
Old 01-16-2011, 08:30 PM
sam333's Avatar
BTDC- Before top dead center
Old 01-17-2011, 08:32 AM
is there a trick to set the timing? in the manual it says to use the "sst" and connect it to terminals te1 and e1...can i do this with out the "sst"?
Old 01-17-2011, 08:33 AM
xxxtreme22r's Avatar
paperclip.
Old 01-17-2011, 08:34 AM
so i can just jump the two terminals?
Old 01-17-2011, 08:39 AM
yup. when connected properly your CEL will come on. It might flash can't remember.
this works just as well:
Old 01-17-2011, 08:41 AM
ok im gonna try that right now and see what happens...thanks
Old 01-17-2011, 09:06 AM
alright so i got it to operating temperature, jumped the terminals, and i can get it 10* BTDC but when i drove around the block it backfires a little? timing is still off, if i pull the distributor and move it another tooth will i be ok?
Old 01-17-2011, 09:33 AM
so this is embarrassing...my number 3 and 5 plug wires were switched...one of those late night mistakes...gahh well she purrs now!
Old 01-17-2011, 09:49 AM
hehe been there done that. Don't feel bad.
Old 01-17-2011, 09:52 AM
yea i called my dad and told him what it was and he chuckled and said he did that on our boat one time...except he didn't figure it out, the mechanic did for 200 bucks lol now i just need a cat converter that doesn't have something inside of it rattling and i will be golden
Old 01-17-2011, 09:53 AM
Broom handle will fix that converter.
Old 01-17-2011, 09:59 AM
By whacking it? Hahaha mines welded on both sides...I'm just gonna put a hi-flo on there
Old 01-17-2011, 10:19 AM
hehe nope, by shoving it inside the cat to gut it out.
Old 01-17-2011, 09:00 PM
well yea i guess theres that too...haha
JF9243176
10-08-2017 04:21 AM
yourrealdad
7
07-21-2015 08:53 AM
RyanJ989
06-21-2015 06:40 PM
HBoss
12-20-2004 08:45 AM
Quick Reply: loping idle, no power, 14 miles on a fresh rebuild?
