locker and hubs question
check your local junk yard for a wrecked TRD w/e-locker, theres one local to me, for $300, then you have a selectable for the same price as a lunchbox.
to everyone else, if i were to switch from auto hubs to manual, is it a drop in part or what? my 98 taco had manual hubs and were easy to take out and stuff , but what would i have to do the switch the auto-manual?
for a daily driver and part time off-road truck, you might look into a front locker, and a tru-trac in the rear. that's the setup i wanted to go with for a while, but i decided in my infinite stupidity, that i'm going to find and adapt a toyota e-locker to the rear of my '94 4x4, and get a locker for the front. (it has manual hubs, so they're only locked when i need 4 wheel drive, aside from the 20 miles a month i lock them in for the hell of it on my way to work)
i found a tech article on 4x4wire (i think) that shows how to adapt the e-locker to older toyota pickups.
-shaeff
-shaeff
#28
Are you sure about that? From what I have seen with auto hubs of that nature once they lock you are fine, but it takes reverse to unlock them, in 2wd. Reverse in 4wd should work fine.
#29
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
MTLroadierunner
07-20-2015 03:07 PM
