Intermittent starting problem with 22RE!!! Help
Old 04-07-2011, 02:20 PM
desertRunner3.4L's Avatar
Last summer I noticed my truck would an intermittent starting problem. I would get acc.. power but it wouldn't even turn over let alone start! It did this for about a week and then the problem went away. Since last summer, I've replaced the starter, hooked up some new battery terminals and I also put In a freshly re-built 22re from Attarco which isn't relevant, but after a few months I'm starting to get the same problem back! I try to crank it over several times and it doesnt turn over at all, but i still get acc power to everything else like lights and stero. Then I will try it again after a couple minutes and it turns over and starts imediately. So what do you guys think? could it most likely be a loose or dirty connection at the ignition switch or is it the coil going out??
Old 04-07-2011, 02:46 PM
yotarob2005's Avatar
I have the same problem with my 86 4runner and I'm pretty certian it is the ignition switch. I can leave the key in the run postion and use a jumper wire from the battery to the signal (small) wire on the starter and it will start right up.
Old 04-07-2011, 03:10 PM
yeah, I'm left to believe it's the ignition switch, but I might tinker with it and find out! What sucks is the ignition on our yotas are in the steering column.
Old 04-08-2011, 07:08 AM
MrPeepers's Avatar
possibly neutral safety switch? Try wiggling the shifter back and forth while in crank position, tehn put it in neutral and wiggel it there too. Otherwise I am guessing perhaps a loose/dirty ground somewhere, or maybe a relay.
Old 04-15-2011, 09:39 AM
87hillbillyoter's Avatar
might be the starter contacts. i get the same thing but i gotta tap my starter a bit.
Old 04-15-2011, 09:59 AM
James Woods's Avatar
He said that he replaced the starter, I am going to second the ignition switch.
Old 04-15-2011, 10:49 AM
ah didnt see that. although i replaced mine about a year ago and i still gotta tap it
Old 04-15-2011, 12:52 PM
Sportsmanphil's Avatar
Last summer and now again this summer.. could be a temp related event.
CTS anyone?
Old 04-15-2011, 12:56 PM
it aint summer up here haha its still in the 30s where we are. so i doubt it
Old 04-15-2011, 01:06 PM
Might have a point there.. we are already in the 80's here yet 3 weeks ago we had our last snow. 2 seasons here, cold, hot.
That said I would lean toward the ignition switch.
Also, you turn your key to ACC and all electrical items come on, what do they do when you roll it over to crank position? Anything dim?
Old 04-17-2011, 01:52 PM
Flash319's Avatar
COR relay ....... AFM/COR start circuit....... Cor relays go bad since these trucks are getting on in age. They are also not sealed and get condensation in them and rust.
Crazychris1871
06-27-2016 10:38 AM
jennygirl
11-17-2015 11:24 AM
Ichneumon
09-27-2015 04:21 PM
Sandman
07-23-2015 08:15 PM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: Intermittent starting problem with 22RE!!! Help
