Injectors Bad?
Old 03-31-2008, 06:16 PM
Silas's Avatar
Injectors Bad?
Well a few days ago my friends 1986 22RE started running quite badly, blowing lots of black smoke out the pipe.
Now, it will start for 1/2 second and thats it.
Pulled a fuel line and checked pump, working good. Check AFM, all to spec and tried another one just in case.
Now, went to change the fuel filter, and found out someone spliced a piece of line in its place. Disconnected it, a bunch of black gas with a bunch of crap came out of the line coming off of the fuel rail/injectors.
Sooo...question is....Should we just toss these ones and swap for another? Or are they salvageable.
Old 03-31-2008, 07:49 PM
dcg9381's Avatar
Likely salvagable - send 'em to witchhunter.com...
I suppose they could be stuck open...
Does the oil smell like gas?
Old 03-31-2008, 07:59 PM
MonsterMaxx's Avatar
+1 on send them to witchunter. Good prices, good service, nice guy to work with. He can service them if needed too.
Old 04-01-2008, 12:07 PM
Silas's Avatar
yes i believe the oil smells somewhat like gas...?
Old 04-01-2008, 12:17 PM
GT88Yota's Avatar
As other said they can probably be cleaned/serviced which is a lot cheaper then buying new ones.
Old 04-01-2008, 01:27 PM
dcg9381's Avatar
Make sure the oil gets changed. Extra fuel can "wash" the cylinders of oil and cause a much more significant failure...
I've seen an injector stay open once - it'd be odd for all of them to stay open and would indicate a break in the wiring harness and unintentional grounding... Do all 4 plugs look rich?
Another cause could be an unplugged or shorted engine temp control sender - the one in front of the lower manifold. Unplugged = super cold = super rich.
Old 04-01-2008, 01:45 PM
Ganoid's Avatar
It would be worth checking the cold start injector as well. I have never seen one stick open but if it did you would get similar results.
Old 04-02-2008, 02:09 AM
mjwalfredo's Avatar
You could also try Rich at www.cruzinperformance.com . He did an excellent service on my injectors with over 200k mi on them.
Old 04-02-2008, 04:04 AM
Ganoid's Avatar
I used Cruzin performance as well they did a good job for not a lot of coin.
Old 04-02-2008, 05:09 AM
zlathim's Avatar
Good post dcg- Diagnosis before spending money usually makes the job go better, financially speaking. I like posts like yours that give a guy a few things to think about instead of rushing out and spending a ton of money on parts they don't need.
Doug4320
03-24-2018 10:11 PM
raptor510
02-17-2017 07:11 AM
RatOmeter
10-22-2015 03:17 PM
pyramid
07-29-2015 06:53 AM
Quick Reply: Injectors Bad?
