How to I get this !@#$ rotor off?!!
Old 09-07-2008, 10:22 AM
mt_goat's Avatar
You're going to need a lot more help, start reading here: http://www.4x4wire.com/toyota/maintenance/front_end/
The part you removed is called an ADD flange, it uses the same gasket (paper) as a manual hub. You could use RTV too, but its harder to do trail repairs with the RTV for a gasket.
Old 09-07-2008, 10:52 AM
waskillywabbit's Avatar
Quit trying to wing it before you fubar something and read the link above from mt goat.
Old 09-07-2008, 03:56 PM
AxleIke's Avatar
x2.
There are lots of things, like torque settings, you'll need before you put this back together
Old 09-07-2008, 04:06 PM
Team420's Avatar
Originally Posted by Green93
There are 2 threaded holes on the black thing with nothing in them. Find 2 bolts that fit, I think I used 2 of my hood bolts since I had it off anyways. Tighten the 2 bolts in the holes, alternate between them and you will see the black thing start to move. You don't need to loosen it too far. About 1/8" gap will be enough. Then simply remove the bolts again. The cone washers will fly off so watch your eyes. You might have to tap a couple but nothing difficult at all. There is no need for a torch or anything like that. I didn't even have to use penetrating spray.
Good luck,
Jason
Yeah...this is exactly how not to do it.... I did the same thing my first time, and those cones fubar'd the threads on the bolts.... use the screwdriver method, or brass drift, just dont beat the housing too hard, heat helps a lot also.
Old 04-13-2009, 03:51 PM
  #25
Cansler's Avatar
I've successfully replaced the old CV joint and I am now in the process of putting things back together. I noticed the part in the picture with the 7 bolts around it has a cut in the rubber and I need to replace it. Anyone know what it's called?
Old 04-13-2009, 04:00 PM
  #26
iamsuperbleeder's Avatar
did this really take you 8 months?
jk...
I honestly cannot remember the name for that thing, and I left it alone when I did my wheel bearings last. I believe it's more or less just a dust sheild, as the inner seal on the bearing hub assymbely is actually what keeps the grease from getting out, or water from getting in for that matter
Old 04-13-2009, 04:02 PM
  #27
It is just a seal that bolts to the spindle. Comes in all knuckle service kits or get separately from the dealer.
Old 04-13-2009, 04:07 PM
  #28
Cansler's Avatar
It really has taken me 8 months, haha!
Old 04-13-2009, 05:00 PM
  #29
bigt's Avatar
took me 2 months to do a clutch
Old 04-13-2009, 05:27 PM
  #30
gary96360's Avatar
lol i took 20 hours with a partner to change a clutch but this was on a kenworth ha, and i was learning.
Old 04-13-2009, 05:30 PM
  #31
I once changed a clutch in 5 minutes flat!!!
it was a small cintrifical clutch on a go-cart
Old 04-13-2009, 05:40 PM
  #32
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Well, if we ever need to have a go cart clutch changed......we're callin 'Bleederdude!!!!!
Old 04-13-2009, 05:43 PM
  #33
hey that's what I'm here for!
  #34
bigt's Avatar
yea it was my first time i went and bought the jack a week in... let the bolts soak for a week look everything over for a week.. only ever did front breaks before that...
now id tear into anything on a 22re.. and am learning alot about my new diesel!!!
paying mechanics is lame unless its for something specialized
Old 04-13-2009, 05:47 PM
  #35
Junkers88's Avatar
*sigh* iamgocartbleeder.......... One more to add to the list.
Old 04-13-2009, 05:48 PM
  #36
BigBluePile's Avatar
Old 04-13-2009, 05:50 PM
  #37
<-- that should really be a smilie, lol
Old 04-13-2009, 06:02 PM
  #38
shooooot soon to be:
iamfloppytimingchainhitmythumbwithahammeragainblee der
Old 04-13-2009, 06:08 PM
  #39
Old 04-17-2009, 05:17 AM
  #40
Cansler's Avatar
Well I finally got the hub assembly back on there, and the 4Runner is back down on all four wheels. I have to torque the differential bolts before taking it for a little test drive. Next up: a) passenger side rotor replacement b) uninstalling the factory alarm (TVSS piece of crap).
Thanks to the community of members for their help on this particularly challenging job.
ladybugRC
458
08-21-2020 10:41 AM
Kamaloha
10-16-2015 05:13 PM
the_supernerd
10-01-2015 09:20 PM
hiluxinargentina
09-30-2015 05:51 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: How to I get this !@#$ rotor off?!!
