how high do you rev your 22re?
Old 12-06-2010, 06:56 PM
  #81
sebastianholmes's Avatar
well, no tach for me, but if im trying to go fast i hit 30 in 1st, 50 in 2nd, 60 in 3rd, 80 in 4th, not really sure it can go much faster than that. oh and thats on origianl everything with 199,000 miles lol also, 32x11.5x15 tires and 4.10s
Old 12-06-2010, 07:06 PM
  #82
then i wave to the school bus as it passes me lke im parked lol
Old 12-06-2010, 07:13 PM
  #83
87hillbillyoter's Avatar
Originally Posted by drew303
Whats an RPM guage? hehe
If your lucky like me you have a combined speedometer/RPM guage... STOCK. ;-P
I shift from 1st @ 20mph. I never take 2nd past 36mph, and 3rd I never take past 55mph and 4th never past 70mph, but usually more around 65mph I shift into 5th for highway cruising.
1987 22R cluster. I have NO idea what rpm's im shifting at. I just go by how it feels and what I hear. At the top of each gear (at those mph) something under the truck rattles, probably exhaust so i figure thats high enough, time to shift. hehe
wow thats like exactly what i do haha exept 2nd is 33 for me haha
Old 12-06-2010, 07:18 PM
  #84
combatcarl's Avatar
OK, I cheated, I have over 300,000 but its a rebuilt engine, all to stock spec, plastic guides and all. No tach here, (waiting for funding on a SR5 cluster...) but I shift when she tells me its time to shift... I'm usually in third by the far side of a long intersection. I'll pull hills in third at around 45-50 if they're long enough, but I drive like an old fart...I'm usually in no hurry and she'll run longer that way. It's a little 4x4 four-cylinder truck, not a Porsche. I do get a funny whining, ringing, rattle on a higher RPM downshift, but I think that's the exhaust.
Old 12-06-2010, 08:02 PM
  #85
Moonfish's Avatar
I used to not rev it up at all but that makes it really slow. If you're lugging the engine with your foot to the floor, that isn't going to be good mpg. With 31's, I cruise around in 4th most of the time. I don't use 5th until 65 or if there's a tailwind.
Old 12-11-2010, 06:19 AM
  #86
AH64ID's Avatar
Originally Posted by levi_plummer
where can I get this done at? I am only getting 15 mpg with a new o2 sensor (densoe), isr, 268 torqr cam, header with thrush welded 2 1/4 pipe, egr and all other nonsense things removed!
You will have to check with local shops.
Old 04-28-2011, 08:12 PM
  #87
RogueYota's Avatar
Ok so my 22r has about 20k miles on it now. So im pretty sure that its plenty broken in. I have touched 5K only twice. and I rarely ever touch anything over 4K. I want to but for some reason im nervous to. I mean i know the motor can handle it....why would they put the redline way over there if I couldn't touch it? idk maybe I should start. Even when I pull hills im not over 4K.
Old 04-29-2011, 07:36 PM
  #88
crg1990's Avatar
I always shift between 2500 and 3k. I've stock 4.10's and 32x11.50's on my 85 22re. I know its slow but all I've owned is Toyota pickups so I guess I've just gotten used to it.
Old 04-29-2011, 07:58 PM
  #89
baddest94's Avatar
I dont have a tach 1st 15-20 2nd 30-35 3rd 45-50 4th 55-60 5th 60-up. thats with stock gears and 33s basically just shift when it sounds like its almost maxed lol
Old 04-29-2011, 08:11 PM
  #90
BoredOutnJackdUp's Avatar
my old toyota i would hit 6500-6800 when wheelin sometimes.
with current i shift around 3500.
Going up the sexton summit i was cruising 60 in 3rd gear around 5k.
Takes it like a champ!
the 22r(e)'s like to be high in rpms
btw these are all with 33x12.5s and 4.10s
Old 04-30-2011, 12:37 AM
  #91
Sportsmanphil's Avatar
My truck is stock gears and tires.
If im in no rush and no one is behind me, I will shift anywhere from 1800-2000. I will also skip 4th.
In traffic, only not to piss anyone off, I run it to 3000-3500.
Once in a while I will run it to 4500 just to blow it out and to check it for any kind of carbon knock etc.
Flat ground its actually difficult to push it much past 4500 with out dragging it out. The engine drops off a good bit after 4500.
Old 11-02-2012, 09:52 AM
  #92
Paperthinedge's Avatar
Mine sees 4k regularly. When im serrious i take her to 5.500rpm. Gets to 60 while still in 2nd. used to be very slow when i got her. Has a pacesetter full exhaust. k&n cai. Gotten it to 125mph. but didnt like the red line.tires werent rated for more
Old 11-06-2012, 01:24 PM
  #93
Badger62811's Avatar
Wow. Driving habits vary big time with our rigs. I'm in 4th gear at 32 mph. Don't know how I do it, but every time I shift to 4th I check my gps and I'm at 32. I usually shift around 2200 rpm. Sometimes 2000. Every once in a while I'll leave her in 2nd and go up to 50.. cuz the speed limit is only 45... I'm also baby-ing my tired clutch, and broken U joint.
Old 11-06-2012, 03:38 PM
  #94
B-Fake's Avatar
I usually shift around 3K unless I'm going uphill. Depending on the grade I'll shift around 3500-4000 or just leave it at 3000-4000 till I'm at the top. I'm rolling on 33's with 4.30's so it's not like I'm going anywhere very fast anyways. I usually average about 18 MPG.
Old 11-06-2012, 08:50 PM
  #95
westjohns yota's Avatar
i shift at 4200 and take it too 5000k when it pissed off and wanna get somewere and thats with 5.29s detriots and 36s, i get a steady 20 mpg in town if im being nice
calderp
Engine Swaps
08-16-2016 05:15 PM
RatOmeter
10-22-2015 03:17 PM
calderp
07-27-2015 09:58 AM
Cbr954ryder
07-25-2015 06:32 PM
kcaudill
07-20-2015 12:06 PM
Quick Reply: how high do you rev your 22re?
