Help with Auxiliary Fuel Tank Repair Problem
I'd leave the fitting in there, cut the broken part flush with the rest of the fitting, and epoxy a thick disk of hard plastic over the top. Then drill and tap that. No big deal if it doesn't work, you needed a new fitting anyway right?
Whatever adhesive would need to be compatible with gas..
Find the fitting and fix it yourself:
http://www.harborfreight.com/welding...c-welders.html
Here is an interesting how to video on plastic welding I found that may help...
http://www.youtube.com/watch?v=I2pQKPxZMd0
TURBOrunnerNM
07-22-2015 11:01 AM
