Headlight Ground?
Old 03-02-2009, 03:30 PM
Hilux808's Avatar
Headlight Ground?
Anybody know off hand where are headlights are grounded on 2nd gen 4runners? Thanks...
Old 03-02-2009, 03:46 PM
4Crawler's Avatar
Yep, they are grounded by the headlight/combo switch to the cab ground:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
Old 03-02-2009, 03:55 PM
Hilux808's Avatar
Hey thanks 4Crawler but do you know where the "cab ground" is? The exact point where I can find the ground for the headlamps/switch?
Old 03-02-2009, 04:00 PM
4Crawler's Avatar
On my '85, it is behind the driver's side kick panel, sort of under the carpet as I recall. Look for a big screw into the sheet metal with a bunch of brown insulated ground wires running to it and that is the ground point. And if you suspect a problem there, don't just look at the wires and call it good. Actually remove the screw, use a wire brush to clean up the ring terminals and then even hit the sheet metal under the screw with some sand paper to get down to bare metal.
But also check the contacts in the headlight/combo switch, that is where problems usually occur first:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old 03-02-2009, 04:03 PM
Hilux808's Avatar
awesome 4Crawler! thank you!
live4soccer7
05-11-2016 06:52 PM
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Headlight Ground?
