It is happening again...
remove the fuel filter and blow in it, it should be fairly easy.
if the fuel filter checks out let the truck sit for a day or so and have someone start the truck while you watch the tailpipe. look for a bluish smoke.
toyotas have been forever infamous for oil seeping past the valve seals which if a fairly large quantity could cause this.
how many miles are on the enigne itself?
I am currently getting a 5 and 6
That was another option I thought about, but this is really weird, no matter how high I turned up the idle, it just plopped faster, kind of like a stroker motor.
A little condensation sometimes, but no smoke. The valve seals are new and were check when we re-tightened the valves.
It may crank and run right today, who knows? I am starting to think about vacuums. What vacuum device or hose is related to idle?
Yeah, check for codes.The TPS is a little tricky, so I want you to try something else first. O.k., your saying that a light pressure on the throttle alleviates the symptoms. This leads me to believe that that there is the problem. ? you say. There's an adjustment that limits the amount the throttle plate can shut when the accelerator is released.....
i noticed that when you get aftermarket caps they dont come with the little gasket that was previously on there, and instead of finding a new one, just use some black rtv to prevent moisture buildup in the cap itself...thats what i did, and my rough idle when cold went away...i doubt this is going to solve your problems, but alteast no water will get in your cap...
#25
So you've replaced the O2 and are still getting that code, have you cleared the ECU memory? Technically, if you've cleared the codes and it keeps popping up, "then the repair was unsuccessful" that's what it says in my book. I don't quite get how you might fix the 6, could be the distibutor I imagine. Have you tested the ignitor coil?
#26
I would have to look at mine, but pretty sure there are two adjustments there and not just the dashpot one.
#27
Yeah, that deal. It's a little hidden on my 3.0, closer to the throttle body than the dashpot. It's tricky to adjust, but once I got the hang of it, it makes mine quit actin' like he's talkin'. Not too tricky really, there's a noticable change at a certain point in the adjustment, STOP there and make sure it won't fall below that point. It's strange, like when it's not set right the idle will want to be lower than it should be for whatever temp the engine is at, and rougher. If you get that set right though it makes the idle smoother and respond better to the idle adjustment screw also. I couldn't get my idle smooth enough to correctly set my timing till I got the whole thing figured with that limiter adjustment screw (allen head on mine, with a 5/16 nut that loosens so you can adjust it) for the throttle plate dealy, whatever it's called.
#29
Yesterday I spoke to a Master tech and Ted at engnbldr. Both suggested that the TPS is probably causing it to run rich and dump more fuel causing the O2 to trigger. I have found the tutorial on how to adjust the TPS, but can someone tell me how in laymans terms, I am not an auto mechanic.
#31
#33
ok, so basically you need feeler gauges, and a multimeter.
first, see how it works. Set the multimeter to resistance (ohms, or the omega symbol), and notice the reading. Now touch the terminals together. 0, right? so basically it is measuring how much voltage can get through whatever you put the two plugs on.
touch them together, 0 resistance, lots of voltage (as is common for most wire).
next, go to your TPS. put it on the 2nd and 4th pin (according to the diagram). Now, move the throttle butterfly open and closed. notice the number changing? Thats how the computer knows how open your throttle is.
now, we have to calibrate it. We want the value of the throttle being opened a certain amount, to tell the computer the correct value.
You basically put the right feeler gauge in there to open the throttle to a premeasured amount, and then adjust the TPS so that the reading is correct, as specified to the table. Do this for all the positions (including WOT), and voila. Calibrated.
Does that make sense?
Edit: You probably have to take the TPS off, and set it on the workbench.
#34
It's definately easier to do off ten on, but not impossible to do it on. Since you need to check the throttle plate stop and daspot, it would be easier off. If you need to replace TPS, then it's easier off too. That way you can be sure TPS is aligned with TB tangs. You can also flush out the coolant passage, IAC and clean TB easily off.
#35
Just a thought, not sure if anybody mentioned it before but... did you check the throttle bore to see if it was dirty? If you remove the plastic pipe that runs into your intake from your air cleaner and just look into your intake at your throttle plate does it look dirty? Black gunk around the edge, open your throttle, does it look dirty on the back of your throttle plate? You may want to clean that out, it will cause the problem you're having. I've seen motors idle like complete dog ˟˟˟˟˟ with dirty throttle bores but run great at open throttle... Maybe you're bore is so dirty that its clogging up your idle air adjustment screw and thats why you're not getting a change in idle when you adjust it... Seen that before as well.
83yotastockR
11
11-10-2015 06:54 AM
zombie_barbarossa
10-02-2015 10:54 PM
