Fuses, Relays, Fuse Blocks ID and Locations - 1986 4Runner / Pickup
Old 03-09-2021, 04:51 PM
RAD4Runner's Avatar
Backup/Reverse Lights take power from the 15A Engine Fuse
Originally Posted by Santi
...I can’t find anywhere the fuse from the backlights.
Thank you!
You mean backup lights? They take power from the engine fuse. I know. Toyota electrical engineers in those days were not that brilliant.
Engine Fuse Powers:
Combination Meter (dash gauges, not backlights)
Power Window Relay
PPS Computer
Neutral Safety Switch
O/D Off Indicator
Back-up/Reverse Lights
Alternator IG wire
Check Engine Light
The following 2 users liked this post by RAD4Runner:
JustDave (01-16-2023), Santi (03-09-2021)
Old 03-09-2021, 04:54 PM
Santi's Avatar
Thanks a lot
Sorry, muy bad, that was exactly what I was looking for!
The following users liked this post:
RAD4Runner (03-09-2021)
Old 01-16-2023, 08:10 AM
JustDave's Avatar
Hey I'm trying to figure out where ad what the lettered lines lead back to or mean. Trying to follow the heater relay red and black wire that goes back to gauge cluster. And my diagram doesn't say anything about figuring that part out.
when I think switch or resistor went out it took out gauges
Any advice or info welcome thank u
Old 06-06-2023, 09:10 PM
dluke12's Avatar
Relay for power windows?
Hello all
I just purchased a 1989 Toyota 4Runner and am having some issues finding my power window circuit and wondering if there is a relay for the windows also. I did end up figuring out where the circuit it and there is power going through but not getting any power out to my switches on either door. Wondering if anyone can help me out On here
Old 12-03-2023, 01:04 PM
  #25
Mauirunner's Avatar
2 pin connector
Does anyone know what that 2 oin connector is for with the black and black / white cables.
Old 12-03-2023, 10:25 PM
  #26
RAD4Runner's Avatar
Model-year-engine-tranny-trim please.
And show zoomed out picture so we know location of part in question.
Old 02-06-2024, 07:50 AM
  #27
saiwut's Avatar
Fusible link wire
Heyya. I have a 1986 4x4 pickup 22r (carb). Can anyone give me specs on the fusible link wire (2.0L on the diagram) (or a recommendation on a slow blow circuit breaker replacement) hoping for gauge/ length or amp rating. Y’all rock
Old 02-06-2024, 02:53 PM
  #28
saiwut's Avatar
Think I found it
Did a fair bit more digging and I think this is what I was after. I’ll leave this here in the hope that someone else who needs it can find it more easily (although no garante I’m right about this)
Old 03-29-2024, 06:30 PM
  #29
osv
osv's Avatar
i don't know what that connector/wiring is for, but fwiw i can confirm that my '86 4runner has the same thing, it's located right above the fuse box.
TimZ
7
08-12-2020 07:25 PM
summerprophet
13
11-09-2013 05:38 PM
dgillen
06-12-2011 09:19 AM
flipside915
04-26-2010 11:08 PM
codeman720
03-14-2007 06:13 PM
Quick Reply: Fuses, Relays, Fuse Blocks ID and Locations - 1986 4Runner / Pickup
