Front crankshaft key size
Old 07-07-2006, 05:46 PM
2ToyGuy's Avatar
Help! My '87 p/u's (22R engine) front crank bolt backed out on the highway. I got the truck stopped real fast, and there's no major damage to the harmonic balancer or crankshaft nose. I am pretty sure I just spun the pully on the crank a few rev's then got it shutdown. The bolt goes back in properly, and the harmonic slips onto the crankshaft with the same fit it always has. Both the harmonic and the crank are nice and smooth still. My problem is that the key that holds the harmonic in place on the crankshaft vanished somewhere on I-5 North of Harris Ranch...
And I can NOT find the size of the key so I can replace it. I measured it with a Micrometer, and I got an inside measurement of 0.095" on the harmonic's keyway. The closest key stock I can find online is a 3/32", or 0.09378". Is this right? Will this fit and hold correctly? Is there a part number for the key? If so, where can I find it? Can I order it online?
Any help on this will be hugely appreciated. I want to get my poor little truck going again...
Old 07-08-2006, 07:08 AM
Sonofmayhem's Avatar
i went to a junker and got mine.
Old 07-11-2006, 11:01 PM
the_supernerd's Avatar
I agree that a junkyard would be a good choice. Have you called the Toyota dealer?
Old 09-09-2006, 08:33 AM
tntoyota22's Avatar
napa carrys them in stock
jasonty
41
12-23-2018 01:00 PM
gary4runner
09-24-2015 12:53 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Front crankshaft key size
