Experience with ingition control module
Actually what I decided to do is buy an aftermarket performance ingnitor from Toyhead Auto. Its cheaper and more powerful. Its the Igniter Box, Multiple Spark Discharge Ignitions System.
I'll let you know how it works.
I'm confused. It doesn't say "22r"? But the pic of your ecu....
#25
On a whim I pulled the distributer cap and cranked the engine to see if it was even spinning and it wasn't. So I pulled it out and a bunch of teeth were broken off. So I'm guessing thats why there is no spark and why it was misfiring before.
Tommorro I'll install a new one. Maybe it wasn't the ignitor at all.
#29
#31
it's weird that if 5 teeth were broken the distibutor still wouldn't spin... since the gear is helical cut... unless a 5 teeth were next to each other.
THEN you have to wonder WHY 5 teeth were borked... and I'd venture to say that if there were broken teeth on the dizzy driven gear, there'd be broken teeth on the cam drive gear.
RyanJ989
11
04-07-2021 09:41 AM
anniesball
10
09-15-2015 05:41 PM
djpg2000
09-07-2015 10:36 AM
1907035210, 22re, 82, 8962035160, control, igniter, ignitermodule, module, number, oem, part, pickup, toyota, truck, venom
