exhaust gasket?
Old 08-23-2006, 04:41 PM
vdog's Avatar
Question exhaust gasket?
Hey, new here, having a bad day...my wife pulled into the driveway and this outragous noise is coming from the drivers side, near the exhaust manifold. Won't idle and sounds like it's about to explode. I didn't think I would have had exhaust manifold gasket trubs, my rig has about 103,500 miles on it. But, I don't know what else it would be. it's a 95 sr5, v6, 3.0, auto...
any ideas....? [I am mechanically challenged. ]
Old 08-23-2006, 04:46 PM
Elton's Avatar
Welcome to YotaTech.... it does sound like a gasket problem its not a easy job replaceing them
Old 08-23-2006, 04:53 PM
vdog's Avatar
it's sounds loud. I haven't any experience with exhause manifold gaskets, could it be something else ?..the oil pressure has been running low for the last 20,000 or so miles and will only go up as you rev the engine. I'm lost....
Old 08-23-2006, 04:55 PM
vdog's Avatar
another note, I went out to try to start it again, and it won't stay running...
Old 08-23-2006, 04:57 PM
Elton's Avatar
well it sounds like a bigger problem than a leaky exhaust gasket
Old 08-23-2006, 05:01 PM
vdog's Avatar
will my rig idle if the exhaust manifold gasket is blown.....?
Old 08-23-2006, 05:03 PM
Elton's Avatar
it should ........ should be making a ticking sound
Old 08-23-2006, 05:09 PM
vdog's Avatar
no ticking, but, it sounds like an old tracker. starting up on a cold day.
Old 08-23-2006, 05:11 PM
Elton's Avatar
well thats not good sounds like the vavles
Old 08-23-2006, 05:13 PM
vdog's Avatar
I tried it again, I think it's the head gasket...
Old 08-23-2006, 05:14 PM
Elton's Avatar
check under the oil cap it should look kinda milky
Old 08-23-2006, 05:17 PM
vdog's Avatar
I checked, it's not milky. I don't know why it's not idling properly...?
Old 08-23-2006, 05:19 PM
Elton's Avatar
slight chance it mght of burned a vavle
Old 08-23-2006, 05:21 PM
vdog's Avatar
what does that intale, as for as cost...?
Old 08-23-2006, 05:32 PM
vdog's Avatar
you know I had a 91 truck w/ a 3.0 in it, and the exhaust gasket went in it and I remember that ticking noise you are talking about but, this doesn't have that, it's louder.
Old 08-25-2006, 09:45 AM
vdog's Avatar
I know everyone is on the edge of their seats wondering what happened to my 4runner, well I found a sparkplug popped out, I don't know how it happened but, it must have loosened over time and just popped out.
thanks for your help...
Old 08-25-2006, 11:28 AM
mt_goat's Avatar
I've been hearing of that happening on the newer trucks with a 3.4L engine. It usually screws up the threads too. You may have to have a helicoil insert in the hole. First I can remember it showing up on the 3.0L.
Old 08-26-2006, 04:16 AM
vdog's Avatar
well, I tried to get the plug back in. Couldn't do it. So I took it to a good mechanic I know , he replaced all the plugs and got me going back on the road for $130.00, I don't think thats to bad. runs better, the guy before me had put in two differant types of sparkplugs. I don't get it...it's a nice rig, why would he do that...everything else works/runs great on it.
Probably get a little better gas mileage/performance...
Old 08-26-2006, 04:51 AM
mt_goat's Avatar
Some of the 3.4L engines come from the factory with 2 different plugs. One set of 3 on each head. Don't ask me why.
tj884Rdlx
08-28-2015 12:04 PM
ethanethan
Engine Swaps
08-11-2015 09:09 AM
accuracy
08-06-2015 12:32 PM
Dakotaneu
07-27-2015 12:03 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: exhaust gasket?
