Dipstick Issue
Old 02-02-2012, 05:02 PM
whitecocoa's Avatar
Dipstick Issue
Hey was wondering if anyone had an idea why my dipstick won't read oil levels correctly. I have an '88 pickup, got in good condition and dipstick worked previously for me.
but one day i realized about a week after i put oil in it, it read none at all. no leak, and no oil warning light. so i would put more in and it would read fine... but a week later same thing.
now it wont read any level whatsoever, even if i just put oil in and its cooled down and on level ground. when its warmed up i get a thin diagonal line starting from the bottom of the stick going about halfway up the whole thing; but covering not even half the width of the stick.... if that makes sense. any ideas?
Old 02-02-2012, 05:09 PM
waskillywabbit's Avatar
So you have changed the oil recently? How much did you put in? Dipsticks shouldn't be this difficult unless you are missing the obvious.
:wabbit2:
Old 02-02-2012, 09:08 PM
hiGis's Avatar
have you checked if the dispstick tube is well mounted to the block? mine was a bit loose and just pulling the dipstick out to check the level would take the tube out of its position. the problem is that not only is secured to the block by the actual hole it goes in but it has a bracket and its dificult to tell if it is on or off the hole. (excuse any taping mistakes, inglish is not my native language)
Old 02-02-2012, 09:38 PM
yotaman85's Avatar
i love playing with my dipstick... that being said.. check the compression on your motor if the dipstick is deamed not a problem.
Old 02-03-2012, 03:01 PM
whitecocoa's Avatar
oh man... im so lame, totally just wasnt putting enough oil in... and to top it off a girl pointed it out to me. *face palm
Old 02-03-2012, 03:06 PM
93YotaGuy's Avatar
Just goes to show.... When in doubt, add more oil!
Old 02-06-2012, 01:32 PM
abecedarian's Avatar
"Like, omigod! No wonder my toes don't get stuck on my earrings any more! I'm not bending my legs enough! I'm such a blonde!"
So, where's your lube going Cassanova?
Old 02-06-2012, 02:00 PM
93Xtra-Cab's Avatar
Engines need oil? Huh...*Mind blown*
I can't even make fun of that. We've all had silly moments with our vehicles.
Old 02-06-2012, 03:06 PM
ksti's Avatar
Man, I would have used the old dip stick tube was loose excuse, like HiGi's said.
Old 02-06-2012, 04:10 PM
Badger62811's Avatar
ok I gotta... lmao...
Old 02-06-2012, 04:44 PM
sebastianholmes's Avatar
thats what he gets for thinking with his dipstick.
bigjstang
08-25-2021 12:41 AM
nvdesertrunner
05-11-2020 08:18 PM
dumpster84
04-30-2016 06:03 AM
93toyoguy
08-02-2015 07:41 PM
adammtb
07-27-2015 11:57 AM
Quick Reply: Dipstick Issue
