Difficulty shifting V6 3VZE 5spd
Old 12-09-2009, 04:08 PM
cchinny's Avatar
So, fired up my V6 to plow today and it is a bear to get into 1st gear and reverse and likes to grind unless I really jam it in. It is also hard to get it out of Gear. I have a bad feeling it has something to do with the way the clutch was put in, but I'm hoping it is something simple if anyone else on here has had a similar problem. There is a lot of loose play in the shifter. Low fluid or something else?
Old 12-09-2009, 04:21 PM
toyodually's Avatar
when i put a new master cylinder in mine, i had to adjust the clutch pedal out further, when i did that worked like a champ.
my truck did all the same stuff. adjusted it good to go
Old 12-09-2009, 05:37 PM
sb5walker's Avatar
Mine was like that and the problem was the GL-5 I put in it - too slippery for the synchros. Has shifted great since I got the MT-90 in there, tho.
You also may want to drop in some Marlin shifter seat bushings, too.
http://www.marlincrawler.com/transmi...-shifter-seats
Old 12-09-2009, 06:10 PM
RocknRon206's Avatar
I had the same issue after a clutchflywheel install...adjusted the clutch pedal underneath the dash and work out good.
Old 12-09-2009, 08:03 PM
Jay351's Avatar
Remove the shifter and replace the shifter seat and bushing.
Search it on here, I posted some before and after videos of my insane shifter slop ( could move the shifter side to side 5" in each gear!). the Marlin shifter seat and bushing fixed that.
before you shift into reverse, shift into 2nd or 4th gear. Or really any forward gear, this will let you slip into reverse without grinding.
Old 12-09-2009, 08:31 PM
MaK92-4RnR's Avatar
I know 3 people that drive 89-95 pick ups / 4runners, including myself, that their reverse grinds. and I have a brand new clutch. lol
Old 12-09-2009, 08:35 PM
Jay351's Avatar
I shift into 2nd before reverse, its a habit now! no more grindy grindy! Well unless I try and pop it into reverse while rolling backwards!
Old 12-09-2009, 09:53 PM
rhill's Avatar
x2
Old 12-10-2009, 04:42 AM
Team420's Avatar
Also, check your clutch pedal bracket... the one the clutch pedal is attached to under the dash... they are known to crack, and cause the exact symptoms you described.... if the bracket moves AT ALL... it needs to be welded or replaced.
Old 12-10-2009, 05:37 AM
jskijoe's Avatar
I used to do this but shifted into 3rd and it did the same thing, I'll try 2nd too when I get mine running again.
I think what it does is slow something down inside of the tranny that allows the synchro for reverse to work better...
Old 12-10-2009, 10:01 AM
machine23's Avatar
what is this talk about replacing a bushing in the shifter? i have to really push mine into first, and when i have to back up i need to put it into first before i can get it into reverse
Old 12-10-2009, 11:04 AM
sb5walker's Avatar
Ha ha. And what's all this FUSS I hear... about saving Soviet jewelry? *
Old 12-10-2009, 12:31 PM
totally a bro
Staff
vital22re's Avatar
if the shifter bushing is toast its harder to align the shifter to get into gear. However if you're not low on fluid in the clutch master cylinder theres a good chance your clutch bracket inside the truck is cracked.(common v6 problem)
Old 12-13-2009, 07:21 PM
cchinny's Avatar
Clutch pedal freeplay adjustment fixed the problem. Thanks everyone!
Old 12-13-2009, 10:13 PM
Phantomd aka Zach's Avatar
This could be a somewhat common issue of the clutch bracket cracking and failing, allowing excessive movement. check for cracks in the upper left part of the bracket.
-Zach
Bourbonblues
12-15-2017 05:43 PM
scheuvront1993
09-17-2015 06:17 PM
skypilot
08-25-2015 01:09 PM
toy4whatever
05-20-2007 08:39 PM
photoleif
11
03-13-2005 04:40 PM
Quick Reply: Difficulty shifting V6 3VZE 5spd
