Dash Pot?
Old 06-25-2013, 09:42 AM
easterly81's Avatar
What does the DashPot do?
What exactly does the dashpot due and is it important?
Old 06-25-2013, 10:21 AM
Discombobulated's Avatar
Well since you didn't ask for what on what why or anything else here is a link to Wikipedia
https://en.wikipedia.org/wiki/Dashpot
Old 06-25-2013, 04:38 PM
scope103's Avatar
The injectors spray liquid gasoline, but the engine uses only gasoline vapor. A small amount of the sprayed gasoline clings to the inside of the intake manifold, but at steady state (driving down the road), that gasoline is evaporating as fast as it is getting replaced.
To go from idle to steadily running, it has to build up that thin layer of liquid gas. On a carbureted engine, you have an "accelerator pump." On a fuel injected engine, the injectors stay open a hair longer when the throttle opens.
But what happens when you slam the throttle closed? Not much air, but a bunch of liquid gas evaporating into the intake stream. So the mixture goes very rich, back fires through the exhaust, and ruins the air we breath. So all engines (carbureted or injected) have something to keep the throttle from slamming shut.
If you lose the dashpot, whenever you jump off the throttle you'll dump a bunch of unburned fuel into the exhaust, which isn't good for anything. You can get around it by always closing the throttle gently, but why worry about that when a little gadget will do it for you?
Yes, it's important. Now you know why.
Old 10-04-2013, 07:33 AM
Gevo's Avatar
I appreciate this explanation for what the dashpot on the throttle body does... Interesting... during this rebuild I was looking at it... I won't replace mine, but I won't remove it either..
Old 10-04-2013, 01:02 PM
Robert m's Avatar
so what happens if you dont have one? mine has been missing since i had a new engine put in about 60k ago.
Old 10-04-2013, 01:17 PM
Gevo's Avatar
Did you read this?
Old 10-04-2013, 11:32 PM
RSR
RSR's Avatar
Originally Posted by Gevo
Did you read this?
Over the long term you risk burning up your cat and/or over immediate term backfiring if cat's already removed/element collapsed into powder/pieces...
Old 10-06-2013, 12:47 PM
Robert m's Avatar
Did you read this?
sure as hell didnt
TheBFA
02-15-2020 06:55 AM
zombie_barbarossa
10-02-2015 10:54 PM
Jdgarrison
10-01-2015 05:22 PM
Project90
09-24-2015 11:40 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Dash Pot?
