Dash lights and interior lights wont work
"where you are putting the positive test probe (red), where you are placing the black negative probe."
Be EXACT and detailed. The crystal ball is broken
You can do it that way, but for fuses, they really should be pulled out and ohmed. Otherwise, you don't know for certain if you're getting an in-circuit reading through something else, making it LOOK good, when it's actually not. If you pull it and ohm it out, you KNOW whether it's good.
If you read 0 Vdc across a fuse, it's probably good. Voltage needs some kind of resistance to "develop" it. An open fuse is a great resistance, a normal, fuse, ie: an electrical short, would read 0 vdc across it if it's good, 12 Vdc if it's bad, presuming you're not reading back through other parts of the circuit. Most automotive circuits, at least the older ones, are simple enough that's really an unlikely event, but it's possible.
Just a quick note on fuses
Pat☺
Pat☺
#25
FOUND SOLUTION ! Dimmer was the issue for no Dash-lights no tail lights
So turns out my Dimmer was bad
- Verified power to & from tail light relay
- Verified power to and from the 15a tail fuse
- Verified the neutral of the dimmer
- checked the dimmer on ohms and the dimmer was open . Therefore the Dimmer was the culprit
- tested theory by putting a jumper wire red to white bypassing the dimmer — Dashlights tail lights and DTRL came on.
Thank you for all of your guys help , the diagrams posted above ( even though might be a little different than my truck’s ) helped a ton on understanding how it may of been wired up .
I’ve got a new dimmer coming from eBay it’ll be here this next week
carri5
Nov 26, 2024 09:52 AM
toyota82
Apr 5, 2016 04:35 PM
Izthizcheeze
Dec 24, 2014 11:58 AM
