Crossover exaust pipe removal 3.0
Old 03-23-2009, 04:35 PM
scuba#1's Avatar
Hi, Maybe I'm just no good at using the search menu because I know I read something about somebody else with this problem, but I just can't find an answer. I am doing a HG job on my 1990 3.0 and am at the point where I remove the crossover pipe, and the nuts that hold it in place won't budge! I have applied penetrating oil and waited. The tool I was using was a 3/8" drive breaker bar with a cheater bar on that and a deep well socket with a very small extension. I have been trying from under the truck but just can't get them to move. Any suggestions on how to approach this would be most beneficial. Thanks in advance.
Old 03-23-2009, 05:50 PM
needsomecam's Avatar
you could cut them off with a die grinder or other tool and just replace them.
Old 03-23-2009, 06:13 PM
Justinlhc's Avatar
I gave up on those ers and sawzall'd the whole damn thing off. Gave me an excuse to buy a set of headers. I don't know what I would have done if I had to actually remove that damn crossover.
Old 03-24-2009, 08:44 AM
pitster33's Avatar
my dad and I just took the exhaust manifold off where it goes onto the pipe that runs under the truck then just took the exhaust manifolds w/ the crossover off with the heads. That makes those crossover nuts easy to get at.
Old 03-24-2009, 08:47 AM
OutlawMike's Avatar
Remove both heads with the mainifolds and the crossover at the same time. Takes two people, but works great. Then you can dissassemble the manifolds and crossover on a bench where you have better access.
Regardless, you will most likely have to cut some bolts to get it apart.
I did headers when I did my rebuild, I did not want to deal with that crossover ever again.
Mike
Old 03-24-2009, 09:11 AM
TNRabbit's Avatar
Mike
Damn~~I removed both heads & crossover pipe by myself....DOH! Thought I was going to give myself a HERNIA!!
Old 03-24-2009, 10:55 AM
OutlawMike's Avatar
By yourself? Damn dude, risking manuever. My dad and I each picked up a head from the side and just walked it forward. Your Chiropractor must love you!
Old 03-24-2009, 01:23 PM
95RunnerSR5's Avatar
^x2 i removed mine together by myself as well....it was the suck
Old 03-24-2009, 04:12 PM
scuba#1's Avatar
All right you guys, I finally got them off! It really was the PITA everyone said it would be. I had to cut off two posts with a dremmel and a sawsall (over the course of a couple hours. There sure isn't much room to work in that particular spot!). I wish I would have seen the post about removing everything all at once before I finished. Oh well. It seems like smooth sailing from here as long as all the mating surfaces are all true and not warped. Once again you are all so great. Thanks so much.
P.S. HEADERS!!!!!!...........WHAT WAS THE LOTTERY UP TO THIS WEEK?
09-04-2015 09:27 AM
94 Newbie
08-06-2015 10:33 AM
e_richard
07-30-2015 06:50 PM
hexrain
07-12-2015 01:13 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: Crossover exaust pipe removal 3.0
