coolant tube gasket question
Old 11-29-2006, 11:04 AM
fire5's Avatar
I'm in the process of putting my 22re back together and I'm not sure about a gasket to use. The metal coolant tube that runs behind the head, bends 90 degrees forward to travel to approx. half way along side the head and connects underneath the intake manifold to the manifold where there is a coolant sensor on top (I hope I'm explaining this well). I can't seem to find in my gasket kit anything to fit it. The only thing close is a brass or copper ring but I don't know if that's the one. Does anyone have any ideas or a picture of what to use?
Old 11-29-2006, 11:58 AM
dcg9381's Avatar
I *think* that tube has a bit of a "lip" on it, correct? If so, it's an o-ring that goes there.
Old 11-29-2006, 11:59 AM
dcg9381's Avatar
As seen in this photo - behind the fuel line, correct?
http://lakebox.dnsalias.com/photos/1...d/DSC05525.JPG
Old 11-29-2006, 03:22 PM
fire5's Avatar
Yes, that's the one. I just can't find the suitable ring in my kit. Could it be the copper one?
Old 11-29-2006, 03:49 PM
dcg9381's Avatar
I don't think it's copper, no... Can anyone else confirm? Worst case, pick one up at the hardware store.
Old 11-29-2006, 04:09 PM
fthertime666's Avatar
The coolant line? Cut a gasket out of cereal box. The stock gasket is just gasket paper.
Old 11-29-2006, 04:10 PM
fire5's Avatar
yeah, I was thinking of making one and using RTV sealant.
dcg9381's Avatar
The coolant line where it goes into the lower plenum.. I could have sworn that it's recessed there and requires an o-ring.
Old 11-29-2006, 04:25 PM
fire5's Avatar
Yes, you're correct. It is recessed. There's a bunch of gaskets in the kit that I have no clue what the're for. "O" rings as well. The one that came out of the connection is rubber, circular, but with 90 degree edges to fit snuggly into that recess.
Maybe the replacement is your typical "O" ring. I'll double check my kit.
It might be, but I think he is talking about the connection to the timing chain cover. Its been a while sinc I dun a timing chain.
Old 11-29-2006, 04:26 PM
sorrry late post
Old 11-29-2006, 04:33 PM
Flash319's Avatar
I just put an oring on mine. Hope it works when i put the engine in.......
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
DrZero
18
07-24-2015 11:31 PM
Snort
07-19-2015 07:03 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: coolant tube gasket question
