Brass washers reusable?
Old 01-06-2007, 02:33 PM
benwahballs's Avatar
Just curious if the brass washers that act as gaskets for the bolts that thread into my fuel delivery pipes (89 3.0L) are reusable or not. I know I've reused similar washers in similar bolts, but for brakes. They held up fine, but is this a good idea?
RETARDEDLY expensive gasget kit for this rebuild should have these washers, shouldn't they?
I also just realized looking back at my pics that I put fuel del pipes on top of two rubber spacers, (should be speacer-del pipe- spacer but i put it spacer-spacer-del pipe) so im taking em all off anyway, but will have no way to get these washers until possibly monday.
Old 01-06-2007, 02:49 PM
Targetnut's Avatar
I think I'd be more likely to reuse them on fuel systems than on brakes. After all what happens when your brakes fail?
They are actually copper washers/sealing rings and should be available at your local auto parts store.
a lot of shops have an assortment as well.
Old 01-06-2007, 03:16 PM
I just meant that I could visibly see the bolt on the brakes after installation, and there was no visible leaks, and could be checked frequently. Here, visually spotting a leak would be next to impossible.
living in a remote area with no access to any parts until monday, I would just like to know if anyone has reused these fuel copper washers before.
Old 01-06-2007, 03:35 PM
Targetnut's Avatar
I see them re-used regularly and the vast majority of the time there is no problems.
Don't over tighten them.
Old 01-06-2007, 07:57 PM
thanx man, exactly what i wanted to hear.
Old 01-06-2007, 08:01 PM
GT88Yota's Avatar
I've reused them and not had any problems. I've also noticed that some sizes (i.e. fuel filter) are VERY hard if not impossible to find.
Old 01-06-2007, 11:02 PM
cadman's Avatar
You can reuse your copper gaskets if they are not damaged. Before you reassemble them, lightly lap then on 400 grit wet-or-dry paper with water. Then anneal them by dropping them on a hot plate and let them heat up until they turn red. Now drop them in a cup of cold water. Do this a few times and they are good as new.
Old 01-07-2007, 10:22 AM
GT88Yota's Avatar
cadman, thanks for the tip.
Old 01-08-2007, 05:49 AM
maxpower_hd's Avatar
I have reused them too in a pinch but you aren't supposed to. they are actually called crush washers. The local parts store should have them very cheap. I just bought a combo pack of them for like $2.00. They were in the HELP section.
kawazx636
10-06-2021 03:03 PM
Dale Johnston
11
10-31-2015 10:22 PM
hiluxinargentina
09-30-2015 05:51 PM
AustinTaco
09-18-2015 08:58 PM
VT2LAB
09-10-2015 09:36 AM
Quick Reply: Brass washers reusable?
