Bad Transmission?!?!
Old 07-29-2011, 08:51 AM
my-4x4's Avatar
So my newly found beauty has some flaws...its a 86 4runner 22r-e with a w56 5-speed
The problem is...when I put it into any gear I get noise...sounds kind of like loose marbles in the transmission. I hear it the best in 5th....but in 4th gear it goes away completely. When its out of gear it I don't hear any noise from it...
I did some research on here and couldn't quite find my problem or a solid solution. I read that it could be the input shaft bearing or pilot bearing...any thoughts?
Thanks in advance
Old 07-29-2011, 08:54 AM
TNRabbit's Avatar
If you hear it in every gear but 4th, your bearings are toast (4th is direct drive through shaft). I'm betting if you drop the drain plug you'll find a lot of pieces of bearings.
Old 07-29-2011, 08:58 AM
my-4x4's Avatar
I'ma drop the tranny this weekend...which bearing are u betting are toast? And any idea on what price they run?
Old 07-30-2011, 06:21 AM
my-4x4's Avatar
...bump
chuckross1957
06-28-2019 10:19 PM
mskalmus
05-28-2017 07:51 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Bad Transmission?!?!
