B+ to fp failed help??
Old 02-29-2012, 11:32 AM
fairfaxlineman's Avatar
I jumped b+ to pf with key in on position and fuel pump didnt come on. Then I jumped fp to the actual battery the fuel pump came on and truck ran like a top. What could the problem be
Old 02-29-2012, 11:33 AM
SOrry truck is 1987 pickup fuel injected
Old 02-29-2012, 01:59 PM
OrRunner's Avatar
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Read this link...
Old 03-01-2012, 07:38 AM
scope103's Avatar
Is there power to the B+ connector? You check with a voltmeter. If there is no voltage to B+ you may have an EFI relay that is not working.
No voltmeter? There's no excuse for that: http://www.harborfreight.com/7-funct...ter-90899.html
Old 03-01-2012, 09:58 AM
I know I have asked 50 times and I have spent unknown hours looking through old posts and wire diagrams I just cant find the efi relay on my 87 pickup?
Old 03-01-2012, 10:13 AM
scope103's Avatar
Try this (current) thread: https://www.yotatech.com/forums/f116...ic-box-250159/
Old 03-01-2012, 10:24 AM
YEah that is my thread but I dont see a metal canister relay in engine compartment. plus he has got a newer truck than my 87
Old 03-01-2012, 10:54 AM
Replicant's Avatar
Sorry, didnt see it was an 87 before I posted. I think it is behind the drivers kick panel inside the vehicle. Once you find it, everything else I posted still applies as far as the B+ wire.
Old 03-01-2012, 11:17 AM
I think you are right. Thanks for the help
Old 03-01-2012, 11:30 AM
BMcEL's Avatar
For future reference, the FSM is a great resource for troubleshooting. Straight from the FSM:
Old 03-02-2012, 11:46 AM
abecedarian's Avatar
Someone please correct me if I'm wrong ....
The B+ terminal in the check connector only goes hot when the key is on. So if B+ isn't hot, it would be an issue in the wiring or ignition switch.
I'll check my diagrams in a few but just wanted to put that out.
Old 03-02-2012, 11:54 AM
Replicant's Avatar
Thats correct, it is only hot with the key on. The reason I am suggesting the EFI relay is because that is where it gets it power from when you key on. The switch inside the EFI relay is from constant power to ignition (B+), so when you key on and that relay clicks, it switches the B+ to hot. I only know because I had the same problem, no power to B+, and when I traced the whole thing down, B+ goes into the EFI to get its switched power. Mine was bad, not making the switch to power B+. Replaced the relay, had power on B+ and started right up.
Granted, there could be many other causes, but the relay is probably the easiest thing to check to start with.
Old 03-02-2012, 12:17 PM
@replicant:
Your point is well taken; thanks.
Jumpering battery to the B+ terminal in the check connector will "back feed" voltage to any circuit that is connected to that terminal. It now looks like there's some tracing to do- find out why B+ isn't getting voltage from the ignition switch / efi relay.
(I haven't got to my diagrams yet.... )
Old 03-02-2012, 06:51 PM
BAd efi relay problem fixed thanks
Old 03-02-2012, 06:55 PM
Replicant's Avatar
Glad you got it fixed man.
ladybugRC
458
08-21-2020 10:41 AM
Longbed 90
03-11-2019 12:38 PM
Chicken12
10-14-2015 03:54 PM
Truckwithoutaname
10-03-2015 03:41 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: B+ to fp failed help??
