AFM retarded
Old 06-07-2006, 02:59 PM
Spanky's Avatar
AFM retarded
yes... i did it. i know better. but today has just been one of those days, and like a retard i took off those two screws and blamm-o there goes the next 2 hours soldering little foil thingys back together. that was fun!! at least i know i am not the only one.
The good news is that to my surprise it (so far) is working like a champ!!
Has anyone who has had to solder the connections back together ever had a problem with it maybe coming apart again or anything? my soldering skills are not the best by anymeans, but the connections were holding good from what i could tell.
Old 06-08-2006, 05:49 AM
JRodsrunner95's Avatar
I had this problem and had to solder the tips on my old supra, after i got it fixed and in working order, i drove it around for a while, and then just to make sure that everything was in place, I went back and did another solder job on it, Thats just how i did it, cause i was afraid of it coming apart.
hope all goes well
Jared
Old 06-08-2006, 01:09 PM
InternetRoadkill's Avatar
I rebuilt my AFM. But I didn't pull the wires off be accident. I purposely unsoldered them, removed the electronics and sandblasted the case clean inside and out. Then put new bearings in it. Worked and looked like new.
Old 06-08-2006, 09:03 PM
Spanky's Avatar
ok is it just me or is that just A LOT of work?? were you just bored one day or what?
Old 06-09-2006, 05:09 AM
Nope. took about an hour. The bearings had rust on them, so the vane wasn't moving smoothly. It worked perfectly after the rebuild . Plus I put stainless steel bearings in it so it wouldn't rust again.
Old 06-09-2006, 05:30 AM
TNRabbit's Avatar
Does anyone have pics of this process?
Old 06-09-2006, 05:51 AM
Jeffires's Avatar
I broke mine by accident and re-soldered it. It lasted a few months, then began acting up intermittently. I purchased a rebuilt part from NAPA for $180, and it has been working correctly for several years.
Old 06-09-2006, 12:44 PM
Spanky's Avatar
when you say it was "acting up" what exactly did it do? I want to know so i can watch for this on my truck if it happens.
Old 06-09-2006, 12:56 PM
Jeffires's Avatar
It started running rough and would not accelerate well. It was dangerous to get out in traffic. Once I got up to 40 mph or so, I guess the air flow pushing the flap open helped, because it smoothed out. It usually occurred from dead stop or when driving "in town" conditions.
It gave a CEL which I pulled 2 codes from. I can't remember what the codes were.
You will definitely know if it acts like mine did. If you soldered it, it may hold and continue working fine. I am not the best at soldering tiny wires, so I bought the NAPA part.
Old 06-12-2006, 10:39 AM
Spanky's Avatar
i am not the best in the soldering department either. guess i will keep my fingers crossed that they hold!
Gutted91
01-03-2020 09:48 AM
rubrsidedwn
07-07-2016 07:28 PM
BK2TFUTURE
10-11-2015 08:42 PM
toyotasaurus
09-24-2015 03:30 PM
seab1209
09-03-2015 05:41 PM
Quick Reply: AFM retarded
