Advice On Saggy Rear
Old 09-25-2007, 09:03 PM
Phroze2006's Avatar
Just get an add a leaf lifts it enough and its only 60 bucks
Old 09-25-2007, 09:12 PM
fattirerider's Avatar
Well I would like to have quallity suspension.
I am just confused what I will need. I have been searching so many threads and it seems that everyone says something different is needed.
Besides the kit from trd parts what else will I need, what does it do and where I can get it. Someone with experiece using this set up could you please give me advice.
Old 09-25-2007, 09:34 PM
Phroze2006's Avatar
Do you want something for driving down the freeway or do you want to do alot of playing in the woods, as far as a stock rig just fixing the sag adding a leaf into your suspension would be the least intrusive option and would retain your ride and would look stock...
Old 09-25-2007, 09:38 PM
nix4x4's Avatar
4Runners dont have leaf springs, so you can't really add a leaf. My buddy has three 2nd gens and put air bags in the rear of all of them. They fit inside the coils, look really clean, and work great. And you can air-up or down depending on your needs. I'd look into it if I were you.
Old 09-26-2007, 08:42 AM
  #25
I do like the new coils and shock route. I will be out in the bush with my truck loaded with mountain bikes so I think the ome kit would be best at this time instead on any band aid solution.
I'm just having trouble finding what else is required for this application to keep the truck running true.
Thanks for the help though!
Old 09-26-2007, 09:06 AM
  #26
Sponsoring Vendor
Strap22's Avatar
Call me.....972-880-5616. I can tell exactly what you need.
Old 09-26-2007, 09:08 AM
  #27
frodin1's Avatar
I was thinking about adding the airbags just for heavy loading and towing purposes. I hate to Thread jack here a little, but NIX4X4, what system did your friend use. I noticed that PP has a couple different systems for 3rd gens for under $100. I currently have the Tundra/OME lift. But if im dragging the boat to the lake it would be nice to take the stress off my new coils.
Old 09-26-2007, 10:26 AM
  #28
infiltrator's Avatar
hey,
i just took off my running boards as well
i would recommend the downey coils, they are an easy way to get a lift..
while your at it i would replace the shocks too if you havent already..
heres a write up i have on my subscriptions which should help you out on this.
https://www.yotatech.com/forums/f128...4runner-76341/
Old 09-26-2007, 10:50 AM
  #29
Sponsoring Vendor
Strap22's Avatar
Here try this......https://www.yotatech.com/forums/f37/...s4u-com-54794/
I would not recommend option 1. We have it there for people that want it but it requires a lot of other modifications. I would use the option 2 and the Sonoran Steel Pan Hard bracket or the rod and the rear lower control arm truss. That will give you a complete setup and it is designed for your Gen.2. I ran the same setup on mine and loved it. Like I said before feel free to call me with any questions.
Old 09-26-2007, 01:28 PM
  #30
tomed13's Avatar
Talking
try squats
icentropy
09-16-2020 02:47 PM
tj884Rdlx
08-28-2015 12:04 PM
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Advice On Saggy Rear
