94 3.0: replaced heads, runs poorly-misfires
Old 02-16-2011, 01:03 PM
Chris2184's Avatar
Exclamation 94 3.0: replaced heads, runs poorly-misfires
94 4runner 3.0 200,000mi
the truck was running strong and sounded good, but i was having trouble passing smog i checked and #'s 1 and #4 had low compression so i thought i would change the head gaskets. once i got in there i found craks on the heads so i bought two rebuilt heads from headsonly (an ebay supplyer). after installing the new heads and some rebuilt fuel injectors the engine now runs worse. its rough and #1 and #4 seem to have low compression again.
if the rings on those cylinders are the problems i dont get why its running worse.
thanks
misfire on #1 cylinder. it has spark and compression. how do i tell if its getting gas. ( just rebuilt top end, rebuilt heads, rebuilt injectors)
Old 02-24-2011, 03:52 AM
Fossilized
Staff
dropzone's Avatar
FYI- I merged your two threads and deleted the duplicate thread you had in the 84-85 folder.
what is your compression now? 200K on your 3.0 probably gonna need more than just heads
Old 02-24-2011, 09:18 AM
Chris2184's Avatar
compression ranges from 150 to 160.
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
puffin04
07-10-2015 09:17 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 94 3.0: replaced heads, runs poorly-misfires
