92 pickup when put in gear truck vibrates bad
got a 92 pickup with the 22re and auto tranny when I put the truck into gear it vibrates pretty bad . I have changed the motor and tranny mounts thought that might be the problem but it didn't seem to change it. the truck doesn't have a rpm gauge in it so I don't know what its running at. it seems to idle fine . anybody have a clue what's wrong ? or where/what I should look for? any help on this would be great , Thanks
Vibration only at idle with Transmission in drive..? Reverse..? Any gear..?
Fast idle speed incorrect..?
No vibration in park/neutral..?
Does vibration disapate with increased engine rpms..?
More information on this matter.
[QUOTE=Kiroshu;52226736]Vibration only at idle with Transmission in drive..? Reverse..? Any gear..?
More information on this matter. [/QUOTE
doesn't vibrate in park or neutral , and yes it does in drive , reverse etc. the fast idle speed be incorrect I don't know , to me it seem like it idles a little fast but it does idles down a little once it warms up . how can I check the idle speed ? , thanks
Only vibrates in drive reverse? Like when yout sitting still on the breaks in gear, or when your driving? Sort of sounds like a timing issue.
Vibration Problem
my 86 had the same problem when I bought it at first I thought the flex plate was cracked. but it turned out to be a combination of a miss rigged TPS bad timing distributor was off a tooth and the vacuum lines were all jacked up hope this helps
yes it vibrates when in any gear , it doesn't shake in park though . and if its in gear and your foot is on the brake yes it vibrates you don't of course feel it when your driving .
vac. lines seem good , not sure about the tps or the timing but I am also having trouble with a surging problem too .
I took it out for a quick run out into my field today and it seemed to not to surge , I plan/hope to run it out a little further tomorrow and see what happens then . I did disconnect the battery just to see if that would do anything .
what should the timing be set at ? I figured I would try and dig out my old timing light and just check it or can I use a light on it ? I does to me seem like it ideals a little to fast .
voiddweller
19
05-02-2016 09:10 PM
