92 pickup when put in gear truck vibrates bad
Old Sep 30, 2014 | 11:56 PM
VTToy's Avatar
got a 92 pickup with the 22re and auto tranny when I put the truck into gear it vibrates pretty bad . I have changed the motor and tranny mounts thought that might be the problem but it didn't seem to change it. the truck doesn't have a rpm gauge in it so I don't know what its running at. it seems to idle fine . anybody have a clue what's wrong ? or where/what I should look for? any help on this would be great , Thanks
Old Oct 1, 2014 | 05:08 AM
Schrade's Avatar
COULD be some teeth missing from the tranny's counter-shaft...
Old Oct 2, 2014 | 08:55 PM
Kiroshu's Avatar
Vibration only at idle with Transmission in drive..? Reverse..? Any gear..?
Fast idle speed incorrect..?
No vibration in park/neutral..?
Does vibration disapate with increased engine rpms..?
More information on this matter.
Old Oct 3, 2014 | 05:52 AM
oldblue's Avatar
were the mounts you installed those cheap ass Armor brand from the Zone?
Old Oct 3, 2014 | 10:42 PM
VTToy's Avatar
[QUOTE=Kiroshu;52226736]Vibration only at idle with Transmission in drive..? Reverse..? Any gear..?
More information on this matter. [/QUOTE
doesn't vibrate in park or neutral , and yes it does in drive , reverse etc. the fast idle speed be incorrect I don't know , to me it seem like it idles a little fast but it does idles down a little once it warms up . how can I check the idle speed ? , thanks
Old Oct 3, 2014 | 10:44 PM
VTToy's Avatar
no I didn't get them through auto zone I got them through rockauto and I cant remember the brand ill have to look them up . thanks
Old Oct 8, 2014 | 08:04 AM
VTToy's Avatar
is there anything else I can try or look for ? thanks
Old Oct 8, 2014 | 10:00 AM
rattlewagon's Avatar
Only vibrates in drive reverse? Like when yout sitting still on the breaks in gear, or when your driving? Sort of sounds like a timing issue.
Old Oct 8, 2014 | 05:36 PM
jefro's Avatar
Vibration Problem
my 86 had the same problem when I bought it at first I thought the flex plate was cracked. but it turned out to be a combination of a miss rigged TPS bad timing distributor was off a tooth and the vacuum lines were all jacked up hope this helps
Old Oct 10, 2014 | 08:46 AM
VTToy's Avatar
yes it vibrates when in any gear , it doesn't shake in park though . and if its in gear and your foot is on the brake yes it vibrates you don't of course feel it when your driving .
Old Oct 10, 2014 | 08:49 AM
VTToy's Avatar
vac. lines seem good , not sure about the tps or the timing but I am also having trouble with a surging problem too .
Old Oct 10, 2014 | 12:02 PM
Surging idle when warm? High idle causes that.
Old Oct 14, 2014 | 09:01 PM
VTToy's Avatar
I took it out for a quick run out into my field today and it seemed to not to surge , I plan/hope to run it out a little further tomorrow and see what happens then . I did disconnect the battery just to see if that would do anything .
Old Oct 14, 2014 | 09:06 PM
VTToy's Avatar
what should the timing be set at ? I figured I would try and dig out my old timing light and just check it or can I use a light on it ? I does to me seem like it ideals a little to fast .
voiddweller
19
May 2, 2016 09:10 PM
camdenbuck
Jul 7, 2015 07:33 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
ACZR
Jun 23, 2015 07:55 PM
94 First Responder
Jun 6, 2002 02:19 PM
