91 4runner Pro comp stage II rear install questions
Old 07-06-2013, 01:34 PM
91_TOYOTA_4x4's Avatar
Bought a used kit a while back in decent shape. Fronts done now starting on the back and having some problems. I dont have the install instructions so if somebody does can u post them?
First- the lower link drop brackets mounting is a little weird. As far as i can tell you bolt right in were the old link mounted then theres two holes to mount it underneath kinda offset that i would need to drill into my stock mount? Is that the only mounting?
Second- the upper rear link drop brackets have to holes in te bracket but only one on the truck were the link mounts. What am i missing to mount that second hole?
Donno about the panhard drop bracket yet but that looks like i need to make a hole too.
Any ideas would be great! Thanks!
GreenLion
06-07-2021 10:49 AM
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
Niameyrider
06-25-2015 05:50 AM
Quick Reply: 91 4runner Pro comp stage II rear install questions
