91 4runner Pro comp stage II rear install questions
Bought a used kit a while back in decent shape. Fronts done now starting on the back and having some problems. I dont have the install instructions so if somebody does can u post them?
First- the lower link drop brackets mounting is a little weird. As far as i can tell you bolt right in were the old link mounted then theres two holes to mount it underneath kinda offset that i would need to drill into my stock mount? Is that the only mounting? Second- the upper rear link drop brackets have to holes in te bracket but only one on the truck were the link mounts. What am i missing to mount that second hole? Donno about the panhard drop bracket yet but that looks like i need to make a hole too. Any ideas would be great! Thanks! |
