4wd not working
Old 11-21-2008, 05:53 PM
rev. chuck's Avatar
4wd not working
86 4runner auto the linkage works i have the axle's locked doesnt seem like its pulling from the front. seems to be a pretty basic setup what can go wrong?
trucks been sitting along time i locked the hubs in and drove it a mile before shifting into 4wd to make sure it was fairly lubed in there
any pictures from underneath would help the book doesnt describe much and im new to these
i wouldnt have any doubt if it was missing something since the people who owned this truck before rebuilt the motor - rod bearings
Old 11-21-2008, 05:57 PM
misterzee's Avatar
by jacking up the front a little bit, you could turn the front driveshaft and make sure the wheels are turning. or turn a wheel and make sure the driveshaft is turning... the manual hubs have a barrel inside that is spring loaded, and moves in and out on an eccentric as you rotate the dial. If its corroded inside, it might rotate but not drop into lock mode... unless something was 'removed', like your front driveshaft, there's no reason you shouldn' t have power to the front diff when you move the transfer case into 4wd.
Old 11-21-2008, 06:16 PM
rev. chuck's Avatar
i did have to turn one of the lockers with a pair of pliers cause it was stuck
i planned on jacking the front up tomorrow just wanted a heads up on what else i could look for.
i have to resilicone the stupid water tubes tomorrow as well
add one more thing to the list.
ashersullivan88yota
01-18-2022 05:37 PM
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
cyclist231
07-07-2015 12:56 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: 4wd not working
