steering wheel rubbing??
Old 09-05-2009, 10:44 PM
85yota4x4's Avatar
whenever i turn it sounds like something is rubbing on my steering wheel. has this happened to anyone, or do any of you know what the problem is?
Old 09-05-2009, 10:48 PM
camo31_10.50's Avatar
on your steering?? or on your steering wheel??
if it sounds like metal on metal rubbing in the steering..its likely your steering stops..i grease mine every now and then..and it stops the noise..
Old 09-05-2009, 10:52 PM
85yota4x4's Avatar
it doesnt sound like metal on metal. it sounds like plastic rubbing. is it possible that theres a plastic spacer in there somewhere that is rubbing? and by the way thanks camo you hepled me out alot today. and by the way i got new pics of my truck in my other thread
Old 09-06-2009, 10:05 PM
85yota4x4's Avatar
does anyone know what this could be? id really like to get this figured out
Old 09-07-2009, 12:07 AM
85TurboRunner's Avatar
could it be your steering wheel rubbing on the plastic steering column cover?
Old 09-07-2009, 06:09 AM
4Crawler's Avatar
Where is the sound coming from, as in at the wheel, in the column inside the cab or outside the cab?
Old 09-07-2009, 06:32 AM
Erik Hinch's Avatar
I had one doing that one time, I pulled the steering wheel, and greased the horn contact on the back of the steering wheel....fixed it!
Old 09-07-2009, 07:21 AM
Motomeister's Avatar
i would reinstall your steering column cover probably where its coming from.
Old 09-07-2009, 10:13 AM
85yota4x4's Avatar
its coming from inside the cab forsure
Up&Down
08-11-2015 10:04 AM
RBK
08-01-2015 01:55 PM
terminator
07-27-2015 07:13 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: steering wheel rubbing??
