Marlin diff drain plug question?
Those Marlin low profile magnetic diff drain plug are they the same size as the fill plugs, I'm gonna replace the diff gear oil but I don't want to take one drain plug out and see if they are before repalacing gear oil. If there not the same size then I'll just order 2. One more question is the manual trans drain and fill plug the same as the drain plug on diffs. If so I'll get more for those 2 if there the same size. Where can I get a magnetic oil pan drain plug on-line?
Thanks for any info...
Magnetic Drain Plug
Magnetic Drain Plugs are a great way of keeping metal from building up in the oil. Low profile design uses recessed 10mm Allen socket. Your choice of Aluminum or steel washers. Aluminum washers are designed for transfer cases, and aluminum transmissions (G, W & R series). Steel washer is designed for axle housings and steel transmissions (L series).
http://www.wabfab.org/products/diffe...ferentials.htm
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
icentropy
07-14-2015 10:23 AM
