Bobbed my bed (PICS)
I finally had good weather around here so i decided to bob my bed. I removed 11 inches. Wasn't as bad as i thought it would be. Im really happy with how it turned out. If you have any questions feel free to ask.
Back section removed
11 inches marked, ready to cut off
Cutting away
Inside of bed marked to be cut
How it looks with the section cut out
Grinding the paint away so i can weld it
Test fit
Welding it up
Inside of bed welded up
Outside of bed welded up
Weld ground down
I tried to make it as smooth as possible with the grinder
Put Bondo on and sanded it smooth
Painting the bed
All done
Cutting away
Test fit
Welding it up
Weld ground down
Painting the bed
All done
thats so sick! I'm about to bob mine as well as put an extended cab on my frame where i only had a single to begin with ...so double bob? lol
any tips or problems with welding up the inside of the bed under the bed rails?
Thanks guys. I couldn't be more happy with how it turned out. Next i need to install my high steer and power steering.
BASKETCASE: I only welded the outside parts of the bed, but you shouldn't have any problems welding under the bed rails.
looks pretty proportional now.
also, great job on the bed bob. some awesome welding skills here.
Thanks guys.
Phessor: i used a grinder with cutting wheel to cut it. worked out really good.
Greatskiiiier: sure i can do yours next, just make sure your wallet isnt empty when you show up lol
