Bad Noises from each side of Axle housing?
[IMG][/IMG]
Well I don't think the pic does it justice but both tires are leaned inward at the top and are way out of alignment.There is a nasty squeaking sound that comes from both sides the right side more though and it comes and goes,it increases volume on the side that is opposite the turn(during turning).The tires have been rubbed bald because of issue. Have I broke something? If so what? and how?
I know I need new tires and I don't want to buy them until I figure this out.
Any help would be appreciated. The axle is from an 85 I believe. [I] haven't been wheeling it and I haven't hit anything? The only thing I've done is gone up and down a very steep concrete driveway and it slid a little and it has made the noise ever since.
Check your tierod/draglink and your balljoints as well as basicaly the entire knuckle assembly. What were you doing when the problem started or when the alignment went out?
Which one of these would that be?
[IMG][img=http://img244.imageshack.us/img244/8869/4x4hubbreakdownau4.th.gif][/IMG]
[IMG][/IMG]
Thanks for the help!
[IMG][/IMG]
I'd agree.... sounds like your trunion or knuckle bearings. Jack up the front end. If they are loose or wasted, you'll have ton's of side to side play in your wheels.
Here is a diagram of the knuckle:
Orange circles are where the bearing attaches to the knuckle. See all those shims? Yours should have them as well. Pay special attention to how many and whether they are at the top or bottom when you start taking things apart. Theses shims aligns the knuckle with the housing, and keep the inner axle straight which saves seals and keeps everything working correctly.
Here is a pic of the ball end on the axle:
This particular example has some upgraded gussets, but will give you an idea. Most likely the races will be destroyed, but they come in bearing kits from multiple manufactures and are easy to replace.
This is the Marlin knuckle rebuild kit:
Part number MC1200, $85 (http://www.marlincrawler.com/htm/axles.htm). Should give you everything you need. You will want to replace all the knuckle seals while you are doing this work. Other manufacturers such as Trail Gear also sell rebuild kits. Prices and quality of parts will vary.
Some other parts to consider while you are in there:
Marlin heavy duty inner axle seals
New hub bearings
Not that hard of a job to do, just time consuming.
New hub bearings
Regency
20
01-03-2020 07:43 PM
