82 shifter issues-spins when in gears
if you are talking about the actual stick shifter you may have a broken shift tab on the end the sticks into the trans...other than that not sure...unless the shift knob is broken.
Last edited by dropzone; 11-07-2010 at 12:29 PM. Reason: you forgot the 'f' in shift
Maybe it's an 82 thing...I have the same issue on mine too but not on my 83. It's all wobbly when in gear but still works fine. Curious to hear what the gurus say.
I feel more inclined to say it has something to do with where the stick shifter connects to the transmission rather than the transmission itself since the transmission shifts and works good.
Mine is working fine. the tranny mounts are a little soft therefore making
the tranny bounce around and make its feels a little wiggly.
i could be totally off.
There are some plastic cups in the top of the transmission that you can get to by pulling the shifter out that need to be replaced mine did the same thing. replaced them and it stopped the sloppy shifter syndrome.
Hope that's the ticket for ya!
Mark
Marlin Shifter Bushing are a godsend...
I've put them in every Toyota manual transmission I've ever had, world of difference and gets rid of the "spinny shifter"
http://www.marlincrawler.com/transmi...ver-ball-seats
http://www.marlincrawler.com/transmi...t-lever-socket
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
