New welder! Now I need a helmet around $50
I've had this one for 8months without one single problem.
http://www.harborfreight.com/cpi/cta...emnumber=91212
I picked up a new helmet today...
Lincoln full face (big lens) flipper...$32 at LOWES
I needed another "spare" helmet and it was about time to retire the old Jackson...it is 20+ years old.
#25
*UPDATE*
Helmet works awesome. Far better than that cheap auto-darkening unit from HF. I am getting better and better as I mess around more and more. I have been welding some 2.5" pipe together with flux core wire. I have a full cylinder of gas ready too!
#26
Looks like a nice helmet and I dig the pattern.
First project you need to do is build a METAL welding table. Look on Lincoln's website under projects. A good table that will serve you well a long time and a great first welding/fabrication project for beginners. Cause sooner or later you keep welding on that wood and those plastic saw horses, you will ruin them both.
Second, get a welding hat to wear under your helmet cause it is only a matter of time before a spark catches your hair on fire or burns it. You WON'T enjoy it.
Third, weld with safety glasses on UNDER your lid and ear plugs, as the more you weld the more junk will fly under there and you DON'T want a hot spark in your eye or your ear. You'll dance in tongues if that happens. Not fun at ALL!
Happy welding!
Happy welding!
#27
Thanks Brian. I have all of those "extra" safety things you mentioned, yet failed to put them on because I didn't think they were necessary. I appreciate the tips and will be sure to wear them from here on out.
Yeah, I saw that welding table a while back when I was researching welders, etc. I am totally with you on that. In fact, I spent about 2 hours in Lowe's yesterday wandering around thinking about a table (one I could build or one I could buy), but left empty handed (except for $5 in sanding discs).
Thanks man. I figured if I posted that pic someone with experience would point some stuff out to me. I really appreciate it.
#28
Don't buy your metal from Lowe's...WAY OVER PRICED...find a local steel supplier...MUCH cheaper...or should be. I built my welding table in less than an afternoon...and it was fun too! If you want some more info on the table, email me and I can tell you what I did in making mine.
Get to using that MIG as well...it is SO much nicer to weld with than flux core...that stuff makes a mess. You can use the 0.025 wire and turn your speed up to about 7-8 and it'll cook like bacon w/ the MIG and weld just as good as the flux core if you bevel edges and prep the materials properly. For heavy duty stuff you are going to need a bigger welder regardless, but I use my Lincoln 135 for everything and don't really need a bigger welder right now. If I do, I go borrow one from FireTaco (Ernie).
This is a great book for 411 and you can get it cheap.
Welder's Handbook (Paperback)
by Richard Finch
TheBFA
02-15-2020 06:55 AM
AnimalGuy
08-29-2015 03:28 PM
