Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
air compressor question
Old 09-21-2011, 12:30 PM
skoti89's Avatar
I am wondering how big of an air compressor you think I would need to run air tools in my garage. I have a napa impact gun and an assortment of cutters and ratchets.
I have no idea what I would need, the old shop i used to work in had a huge 100 gallon or something. Would a cheaper 20 gallon craftsmen work? What do I have to look for in PSI and CFM?
thanks
Old 09-21-2011, 12:43 PM
waskillywabbit's Avatar
Look at cfm at 90 psi, you want this high.
Larger the tank the less it cycles.
2 stage pump 220V
:wabbit2:
Old 09-21-2011, 01:04 PM
wyoming9's Avatar
Smile
Be nice to know How much of a budget you are working with .
I have as a spare a nice Sandborn 5 HP single stage It put out around 12CFM that was fine for impacts ratchets but for grinders it just couldn`t keep up .
Bought it in 1989 from Matco I think I paid less then $1000.00 back then.
Now I have a 7HP 2 stage Big Red that fills my air needs at present .
Old 09-21-2011, 02:04 PM
skoti89's Avatar
about 200-300 dollars. I've seen some 20+ gallon ones at harbor freight and sears for that much
Old 09-21-2011, 02:08 PM
skoti89's Avatar
this guy has 4.7 SCFM @ 90 PSI
Old 09-21-2011, 02:54 PM
4Crawler's Avatar
You can look at your typical tool ratings and see:
- http://www.4crawler.com/4x4/CheapTri...uchAirforTools
I use a 4HP, 11.8CFM 20 gallon, 220V Campbell-Hausfield compressor (single stage but will be going 2-stage when this one dies) and it is reasonably adequate for most tools. Would not work well for sand blasting or anything demanding like that.
calderp
Engine Swaps
08-16-2016 05:15 PM
tj884Rdlx
08-28-2015 12:04 PM
stock87yota
07-31-2015 10:08 AM
calderp
07-27-2015 09:58 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: air compressor question
