Turning back on new hard drive scanning
Several months ago I turned off a feature in XP that makes it boot up quicker.
What I did was read in one of my mags that you can turn off a feature that scans at boot up if you have added any new hard drives on the secondary channel, or added one as a slave to the primary channel along with the stock hard drive.
When turned off the PC boots quicker, but will not detect a new drive.
For the life of me I can not find how to turn it back on, as eventually I am going to add another drive.
I looked in the Device Manager for the IDE drives and clicked on the props for them, but can not locate what I am looking for.
It is somewhere else.
Does anyone know what I am looking for?
It is not to often the PC stumps me, as I am the master over it most of the time, and know my way pretty good around PCs and troubleshooting them.
Thanks,
Thanks,
Corey,
You probably already thought of this. Did you go to your "boot-up"screen and check out your settings? (reboot the PC and use F2)
Did not try that, but I found it.
It WAS in the Device Manager afterall, I overlooked it earlier.
Sorry, my scanner (SCSI) is on my old PC, and I have not updated it to run on the old PC since putting XP on it, so I took a digital pic of the magazine.
It only took me 7 issues to look through to find where I read it before.
http://www.pnw4runners.com/temp/ide_drives.jpg
Mine is currently set to "none", and if I wish to add another hard drive, I just have to click the drop down box and put it on auto.
This does indeed speed up the boot process a bit, but not really needed on my very fast machine, so I'll put it back on auto again.
Eventualy I want to add one SATA drive and make it the C drive, and copy the contents of my current IDE drive to it, and make my current drive the D drive, wipe it clean, and use it for storage and backup.
Much cheaper than paying more $$$ for an external back up drive, and easier than using DVD RWs to back up to.
sharrack
06-26-2015 09:33 AM
