CB Feedback from adjusting mirrors and something in HVAC... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-21-2009, 02:24 PM   #1 (permalink)
I installed a Cobra 18WXSTII over the weekend, and it works great minus 2 things.
First, something in the HVAC system (sounds like a vent closing or something of that nature) is causing feed back at times. I'm not sure exactly what it is, as I heard the noise of whatever before and wondered what it was, but now with the CB, when it goes, it creates horrible feedback.
Also, when adjusting the mirrors, I also get horrible feedback. My ground wire is up around the E-Brake handle on a 3rd gen 4runner. This mounts directly to the body, and has been sanded for metal to metal contact.
The CB coax to the antenna runs under the pedals and into the engine bay, then down the underside of the car.
Does anyone else with a 3rd Gen 4Runner get this feed back with their CBs and if so, any way to fix?
Thanks for any suggestions!
__________________
2001 4Runner Limited 4wd(Black Pearl Emblems) - - Thundercloud Metallic
Eclipse AVN6620 - - Eclipse SC8264 - - Eclipse 89640
Cobra 18wxstii w/ 5' Wilson antenna
Husky Floor Mats & Cargo Liner
Hunter Bull Bar & Piaa 510 Ion Fogs
99 Tall springs w/ Bilstein HDs, ploy steering bushings and anti-sway kit
Bye Bye Running boards and roof rack!
Cbohl51 is offline
Old 04-21-2009, 02:27 PM   #2 (permalink)
4Crawler's Avatar
Might try a different ground wire location. On my '85, I ran power and ground wires directly from the engine fuse box up front back to the CB for the cleanest signal:
- http://www.4crawler.com/4x4/CheapTri...na.shtml#Power
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 04-21-2009, 10:21 PM   #3 (permalink)
Staff
aviator's Avatar
Sounds like a ground problem to me to...
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club - Get well soon Mary
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 04-22-2009, 01:43 PM   #4 (permalink)
eric-the-red's Avatar
I have my CB grounded directly to the battery, along with the power wire and I also get bad interference from the power mirrors. My antenna is on the passenger side fender so the coax runs from the centre console behind the glove box and through the firewall. I've never had any problems from the heater/Ac system though.
I've never tried to fix the mirror issue, I don't move them very often so I just live with it.
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 04-22-2009, 11:45 PM   #5 (permalink)
Staff
aviator's Avatar
Eric you may find that the mirrors have a poor ground and may be causing a dirty return back to the batt. not that it would be a major issue in any case...
if signal noise continues to be an issue there are electronic boxes you can set on the power and ant. lines of stereos and I believe they are available for comms. radios too.
__________________
tinted windows
aviator is offline
Old 04-23-2009, 09:39 AM   #6 (permalink)
Thanks for the input!!
I will run power and ground outside of the cabin and see what happens!
__________________
Cbohl51 is offline
Old 04-23-2009, 12:33 PM   #7 (permalink)
One day I may look into it, I'm sure on a 9 year old vehicle a lot of the grounds could do with cleaning up. But I only ever move the mirrors when I'm offroad and want to see the where the rear tires are going so I can live with a bit of noise. It only affects my CB, the ham radio doesn't have a problem, neither on VHF nor UHF.
__________________
2001 4Runner
Tundra brake swap;
Cobra 75 WX ST cb;
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Hvac pineapple Off Topic Talk 1 01-12-2009 04:44 PM
Hvac Panel 94_yota_pickup Newbie Tech Section 2 09-22-2008 09:25 AM
Any HVAC people out there Lance Off Topic Talk 15 08-21-2005 02:04 PM
Anyone work in HVAC? TDiddy Off Topic Talk 3 08-03-2005 06:11 PM
2009 InternetBrands, Inc.
