Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Why 2 Coax Cables on Stock '00 Radio?
Q1 - Why are there two coax inputs / cables running to the stock Toyota radio, a thick one (perhaps antenna) and a thin one??
I am looking at the Alpine CDA-9886 which I assume needs only one coax input for the antenna, and I assume do NOT need to keep the Toyota Amp. Thanks |
| Sponsored Links |
#2 (permalink) |
pretty sure ones for the am just use the bigger one for fm
#3 (permalink) |
Thanks for the quick reply. Might that have something to do with why some people say they don't get AM reception with aftermarket radios?
If one is for AM, where does it come from, since I don't think they both run from the same whip antenna. |
#4 (permalink) |
the second smaller antenna is NOT for am reception.
the thicker antenna cable is the primary antenna, the one on your fender. the smaller antenna is a diversity antenna, most likely located in your passenger rear window, looks like a defroster element. for the best example as to how a diversity antenna works, have you ever pulled up to a stop light and the radio reception seems to fuzz out just a little? and when you pull forward another foot or so the reception comes back. the diversity antenna is supposed to eliminate that, giving another path for the signal to travel into your radio, the second antenna in your glass. in 14 years of stereo installation, I have seen 1 aftermarket head unit with diversity capability, if memory serves it was a sony, about 10 years ago. also, no manufacturer has settled on a universal diversity antenna plug, so every car manufacturer is different. even the sony just had 2 female antenna plugs labeled main and sub, the toyota diversity antenna would not plug into it. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| stock radio? | MAIDEN | 86-95 Trucks & 4Runners | 6 | 03-07-2007 09:58 PM |
| Stock radio??? | Marc P | General Electrical & Lighting Related Topics | 8 | 07-20-2006 11:51 PM |
| Stock radio | Kenn | Vehicle Audio & Home Entertainment | 1 | 04-12-2005 06:36 PM |
| stock Radio | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-05-2004 10:48 AM |
| 03 Limited Stock Radio | timber725 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 10-28-2003 07:31 AM |
