Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
HELP-1986 toyota 4runner radio wiring nightmare
Old Apr 30, 2006 | 06:52 PM
brando864rnr's Avatar
I just recently purchased a 1986 toyota 4runneer, and naturally the factory wiring harness for the stereo has been clipped off. previous owner had a wire tapped into the 12v constant side of the clock for the 12v constant of the stereo. I don't think this is correct, but I could be mistaken. Any comments and ideas of proper installation are greatly appreciated.
Old Apr 30, 2006 | 08:15 PM
HOJU's Avatar
Are there any wires at all? Here is a guide that might help-
TOYOTA
P o w e r
Memory (+12v Constant) Blue/Yellow
Ignition (+12v Switched) Gray
Ground (-) Brown
Illumination Green
Dimmer White/Green
Power Antenna Black/Red
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Blue
Left Front (+) Pink
Left Front (-) Violet
Right Rear (+) Red
Right Rear (-) White
Left Rear (+) Black
Left Rear (-) Yellow
Old May 1, 2006 | 03:58 PM
Red face
thanks for the helpful information. I pulled back the covering on the wires and found the 12v power wires. my next problem is now the 12v constant wire is not reading twelve volts, it stays at zero, even grabbed another voltmeter thinking it was faulty equipment. maybe thats why they tapped into the 12v constant for the clock, so the radio would keep memory. any more info. is greatly appreciated thanks
Old May 2, 2006 | 08:42 AM
Bumpin' Yota's Avatar
I see that issue on about 80% of all hardwires that I've had to repair. Check the fuses in the kickpanel as well as the fuses underhood in the fuse gang.
Old May 2, 2006 | 09:28 AM
bigacuralvr's Avatar
guessing its a bad fuse as well.
Old May 2, 2006 | 09:32 AM
waskillywabbit's Avatar
I just said forget the factory wiring and wired my system in my 87 all new...and when I pulled up the carpet to start...found about 2 sets of previous wire connected to nothing...so who knows what was in there.
Start fresh and do it right and then you don't have to worry about it. It isn't hard to do it yourself either...just takes some time and patience.
Old May 4, 2006 | 08:07 AM
what is going to be the most effective way of rewiring the stereo? should i run the 12v constant directly from the battery, from the fuse panel, or leave it tied into 12v constant on the clock? i know i can run the 12v switched from the fuse panel, and run a seperate ground from a clean area of metal.
Old May 4, 2006 | 08:21 AM
DavidA's Avatar
I would go ahead and use the clock for the memory wire. It is going to draw less than 1 amp and should be stable.
Just my 2 cents.
arlindsay1992
Jan 23, 2024 01:34 PM
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
