ZJ coil springs - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-08-2006, 11:09 AM   #1 (permalink)
Calbo's Avatar
ZJ coil springs
Hello. New member but I've been reading through the forums for quite a while now.
I'll get right to it: My 93 4Runner's rear is sagging, and I'm looking for inexpensive ways to replace the coil springs.
I have a pair of 98 Jeep ZJ (Grand Cherokee) FRONT coils that my buddy and I got from the boneyard for his XJ, but he ended up not using them.
Has anybody tried frankensteining a pair of front ZJs into a 2nd Gen's Rear?
Thanks!
Calbo is offline
Old 09-08-2006, 11:52 AM   #2 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
I doubt anybody has tried it here, but try it and see if it works. You might start a new trend.
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 09-08-2006, 12:03 PM   #3 (permalink)
Calbo's Avatar
I'll give it a shot.
Is there anything out in the knowledge base (or just something I should inherently know) which makes it a bad idea to use front springs in the back?
Calbo is offline
Old 09-08-2006, 04:37 PM   #4 (permalink)
slosurfer's Avatar
I think spring rate and fitment are the bigger issues. 3rd gens use the front springs out of a fj80 to get a big lift while the 2nd gens use the rear coils. Before you tear it apart, I would at least measure the width of the coils to make sure that they are going to fit.
Also aren't the grand cherokees pretty low with stock coils? It will be interesting to see how it turns out. keep us posted!
__________________
Chris
7th Annual Pismo Jamboree: Sept. 25-27, 2009
'93 4runner SR5 3.0 Auto 4WD
'07 Tacoma Dcab 4x4 TRD offroad
'89 F250 4x4 w/utility bed
M416 1/4 ton military trailer
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
Ronald Reagan
Semper Fi
SLO 4wheelers
slosurfer is offline
Old 09-09-2006, 10:29 AM   #5 (permalink)
Flygtenstein's Avatar
Look at the ZJ springs.
Look at your stock springs.
Is the inner diameter close?
Is the wire diameter close?
Do they have the same number of wraps?
I am going to guess if they fit, they are lower than stock.
__________________
Ease on down the road.
Flygtenstein is offline
Old 09-28-2006, 09:54 AM   #6 (permalink)
Calbo's Avatar
They won't fit.
Even eyeballing them, the coils are very different. The Jeep coils have about 3 turns more, are 4 inches taller, and an inch or two smaller in diameter than the stock 4Runner coils. So... no go.
In case anyone is wondering why the ZJ coils are so much taller, it's because they were taken from the front, not the rear.
Calbo is offline
Old 09-28-2006, 11:11 AM   #7 (permalink)
I wouldn't let the height stop you from trying, but the difference in diameter is a deal killer. FJ80 coils are much taller than stock 4runner springs, but they work. Keep trying, you might find something that'll work.
__________________
Old 09-28-2006, 07:42 PM   #8 (permalink)
Napoleon047's Avatar
FWIW, putting ZJ front springs on the rear of a ZJ gives it 3.5-4" of lift. this is due to the slightly heavier spring rate and the fact that they are taller as well.
__________________
-Peter
86 4runner SAS - Trail Rig
94 FZJ80 - DD
the dirt cheap SAS
Marko Customs
Napoleon047 is offline
Old 10-21-2006, 06:50 PM   #9 (permalink)
Gravel Maker's Avatar
I would ask everyone to back up and think about this one.....
Any coil would/could work simply by repositioning the coil itself or adjusting the coil length(cutting & bending). Coil rates are available from the manufacturers specs but front coils will have a substantially stiffer(less flex) ride on the rear in just about any vehicle. You might check out some of the Coilover shock coils for just about any coil rate(very cheap from Summit or Jegs) and a smaller footprint. Coils are not a cureall but they can be the answer.....I like to play with the width to get the flex and ride I want, we are replacing the rear axle on an FJC tommorrow with an FJ80 rear and going to use QA1 2 1/2" ID coilover springs(~225-250lb), should be fun.....
__________________
Dan Fredrickson
916.600.1945
www.ruffstuffspecialties.com
Register on our Website for Free Stickers & Member Specials
Gravel Maker is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
new stiffer coil springs vs. coil spring spacers caddiver 95.5-2004 Tacomas & 96-2002 4Runners 1 06-12-2006 05:44 PM
Coil springs? callmej75 Offroad Tech 5 04-02-2005 04:27 AM
Coil springs live277 95.5-2004 Tacomas & 96-2002 4Runners 4 03-17-2005 12:48 AM
Help with coil springs... 1994_4Runner 95.5-2004 Tacomas & 96-2002 4Runners 2 07-04-2004 08:35 AM
coil springs Krazxyglue12 95.5-2004 Tacomas & 96-2002 4Runners 2 12-22-2003 10:30 AM
2009 InternetBrands, Inc.
