YotaTech Forums
Go Back   YotaTech Forums > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 09-03-2006, 11:35 AM   #1 (permalink)
Personal Sales Rating: (0)
KODE's Avatar
started my SAS on my 93 toy *pics*
just started torching last night. will post more pics of my progress....
***update 9/3
everything is cut off and grinded smooth.
Click the image to open in full size.
84 axle to be installed.....
KODE is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 09-03-2006, 09:15 PM   #2 (permalink)
Threadstarter [OP]
KODE's Avatar
driver side pic..........ill cut the stock shock mounts off after i fab up my dual shock mounts......
KODE is offline
Old 09-03-2006, 11:50 PM   #3 (permalink)
Staff
Tofer's Avatar
eaklandc
Send a message via MSN to Tofer
now comes the fun part... grinding.. lol
__________________
94 4runner: all the good stuff...
89 4runner: 3.0, Auto, 4.56 gears. 265/75r16 wildcountry ATs. - SOLD
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s..... SOLD.
pacific-crawlers.com
Tofer is offline
Old 09-04-2006, 11:20 PM   #4 (permalink)
Threadstarter [OP]
KODE's Avatar
updated...9/4
got the hanger welded in the front and sides but not the back..tried looking in the back but the radiator is blocking the way of the crossmember.
i decided to use a shackle hanger instead of drilling a hole in the frame. welded it solid. shackle kicked back a bit for a little softer ride on the chevy springs.
picture of my homemade hanger made from box tubing and really thick guage galvinize steel. grinded the galvinized coating off before welding it together and then welded it onto the box tubing.
picture of my front axle setup. everything is hanged and welded. just need to torque everything down then start making my crossover steering and start on the rear.
KODE is offline
Old 09-04-2006, 11:29 PM   #5 (permalink)
Threadstarter [OP]
KODE's Avatar
a side view pic of my front end......with my 32" bfg mud terrains. tires will be swapped to 35" super swamper boggers.
KODE is offline
Old 09-05-2006, 12:18 AM   #6 (permalink)
Tanto's Avatar
Dang that truck is gonne be tall! Then again, that's how you guys on Hawaii roll...
What are your plans for the rear?
__________________
"Prepare for the worst, hope for the best"
2002 Tacoma Doublecab - "TURTLE TACO" Just a bunch of bling on a truck...
Quote:
Originally Posted by deathrunner
Yeah, and my mom's still mad at you.
Tanto is offline
Old 09-05-2006, 10:52 AM   #7 (permalink)
Sleeper's Avatar
Those rear shackles look like the angle is too great to prevent it from hitting the frame. Had you flexed it out before deciding on the angle? Great project. I like the homemade crossmember in the front.
__________________
Surf to Live - Live to Surf
'95 4Runner 3.slow with some goods
'99 Taco 3.4 with some goods
Sleeper is offline
Old 09-05-2006, 11:58 AM   #8 (permalink)
4rnr's Avatar
OMG, just my .02 but I predict a cement truck ride, sailboat like stability, and kia like flex.
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system.
The build up.../f88/1-millionth-sas-my-92-runner-74915/
4rnr is offline
Old 09-05-2006, 11:59 AM   #9 (permalink)
Um... wow. 3" longer shackles, 10" springs, 3" body lift. You must have at least 16+" of lift on that thing now!!! Out of curiosity, why not use the shackle tubes through the frame model?
rockota is offline
Old 09-05-2006, 01:34 PM   #10 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
damn... tall. doesn't look too bad though. might want to plate the ends of the hanger though. and that shackle angle should be fine. that's about where mine is and it doesn't hit the frame. and i'm through the frame with the shackles...
__________________
-Mikey-
1993 4Runner ~ 37" Kevlars | TG Rock Assault front housing | 5.29s | Marlin UM07s | Spartan front | Tacoma E-locker rear | TG HD/RUF front | All Pro rear | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | 5-speed swap | TG duals with 4.7s | Budbuilt | 4xInnovations cage | bumpers | sliders | K&N intake | Flowmaster 40 | Optima yellow top | clear lenses | Hella 4000s | PIAA 1400s | LED rock/party lights
Polygoats 4-Wheel Drive Club
Poly Performance
4RunnerKid is offline
Old 09-05-2006, 09:21 PM   #11 (permalink)
Threadstarter [OP]
KODE's Avatar
the shackles arent going to hit the frame. checked it out already.i got 10" chevy fronts in the rear, with 2" blocks. im thinking of taking the body lift off after i do the dual shock hoops and headers. still debating. also thinking of using the frame tubes, i dont know, i just wanted to be different and weld the shackle hanger to the frame instead. still doing some mods, but ill see when i get the tires mounted on and t-drive it.
KODE is offline
Old 09-06-2006, 05:20 AM   #12 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Look good... but I agree with others... I think youll go past center on those shackles. With the springs as stiff as they are it will take a good thump or attempt to stuff, but it looks like the springs only need to get 1" or less longer to allow the shackles to go past center. Your hangers look to be about 3-4" forword of the thru the frame point, thats a long ways....Thats about the angle I had when I first tried my hangers on my rear leaf swap on the 95... it went past center with me pushing on it, but the springs were much softer....
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 09-06-2006, 10:14 PM   #13 (permalink)
Threadstarter [OP]
KODE's Avatar
so will it be ok for now? ill probably go through the frame later on. but if i have to move it, ill move it sooner. thanks for the coments and suggestions. i really appreciate the help. i would be lost without these forums and guys like you.
KODE is offline
Old 09-07-2006, 07:50 AM   #14 (permalink)
AH64ID's Avatar
I would go out and find a ramp and drive it up that.... if it doesnt go past you might be alright.... if it does i would move it sooner than later... at least its a perch and easier to move than a hole in the frame
__________________
-John
AH64ID is offline
Old 09-07-2006, 09:06 PM   #15 (permalink)
Threadstarter [OP]
KODE's Avatar
so what will go past center? im kinda confused.... for now, ill be using the truck for onroad use only. as far as offroad use, ill be using it in a few months after i regear the front and get a new driveshaft. thanks
KODE is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
1992, 35, 39, 93, bed, boggers, chevy, civic, long, mud, sas, side, tires, toyota, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
SAS into 93 want2wheel 86-95 Trucks & 4Runners 2 05-03-2009 08:32 PM
93 4runner SAS jla123 The Classifieds GraveYard 17 04-25-2007 12:18 PM
SAS started sale..... Marc P The Classifieds GraveYard 5 06-01-2006 07:30 PM
Started my SAS YAY! Breezey 95.5-2004 Tacomas & 96-2002 4Runners 8 01-04-2004 02:58 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
