ScubaFab Tacoma rear bumper
Old 05-10-2010, 11:00 PM
scuba's Avatar
Figured I'd just start this rather then adding pictures to the "my truck got rear ended thread"
Plans : 4X2 for the main body, 2X2 for fender wrap around, 1.5X1.5 for the bed side and tail light protection. All of it is in the 3/16th's-1/4" flavor. I don't do tube, square is easy to work with.
The empty candidate (Bobbed and high clearanced)
Mounts using existing holes in the frame
Mock up
110V/135A Flux core
Current state. It looks bent down because the bedside directly under the light is pushed in. But I assure you that is just optical illusion
That's all for now.
Old 05-11-2010, 03:05 AM
stock as possible's Avatar
looking good
Old 05-11-2010, 07:05 AM
BigBluePile's Avatar
Nice man! Not bad for 110v!
Motivates me to go out and finish...well...add to my rear bumper!
Old 05-11-2010, 07:07 AM
scuba's Avatar
I know right. I used to not be able to dial in the settings and couldn't weld with this thing worth a crap. Thought it was because I didn't have enough power but no I just sucked
Old 05-11-2010, 08:34 AM
stepside trd's Avatar
Hey scub, if I may, when welding with flux core, you always want to drag your weld (puddle), using "C" patterns. When using MIG w/gas, you want to push the weld (puddle), and prep your weld surface as best you can to minimize splatter and better penetration. Keep your gun at a 4-5 degree angle (use two hands if need be). Looks good so far though........
Old 05-11-2010, 05:00 PM
peow130's Avatar
x2 on the C patterns and dragging.
Although with my gun, i hold the handle parralel to the metal and it's usually around 15-20 degrees.
Old 05-11-2010, 06:02 PM
scuba's Avatar
Getting the side wrap arounds done right now (taking a dinner break)
Had to get a new chop saw because my HF one took a dump on my chest today
I have the wrap around sticking out so far so that the 1.5x1.5 will fit on the whole 2x2. It only sticks out about an inch more then my sliders and I don't think it will be a detriment on the trail.
Old 05-11-2010, 07:09 PM
Fossilized
Staff
dropzone's Avatar
Originally Posted by scuba
110V/135A Flux core
Nice job on this thing. I am using my 115 volt $64 HF flux core welder. Figured for the price I got it (on sale plus a coupon) i can use it to learn to weld again...Flapper wheels cure a lot of splatter
Looking forward to seeing the finished product
edit: are you gonna run a brace behind the wheel well too?
Old 05-11-2010, 07:13 PM
tc
tc's Avatar
I would suggest at least beveling the front then, as having a square surface sticking out like that will be sure to get hung up on anything it can.
Personally, I would cut the other crosspiece to keep the side wings just inside the outer edge of the tire.
Old 05-11-2010, 07:20 PM
89silverpu's Avatar
Do you know someone with a tube bender? I think the square bed protection is gunna look funky. Just my opinion though. Otherwise lookin good
Old 05-11-2010, 09:40 PM
scuba's Avatar
LOL HF welder ?
Brace from the side wing to the frame and the main mounts you mean ? Yes, they just aren't on the drawing.
Explain what you mean by beveling a bit better please... ?
I do know a couple people I could go to for tube work. But then I gotta pay them. And then there's the question of how on gods green earth am I supposed to use 15 feet of this 1.5X1.5 square tube...
I've already told my self : If I don't like the overall look with the square bed protection I'll cut it off and pay someone to do some tube work.
Update, both of the side wings are on, welded, ground down and welded again cause for some reason I was getting poopy welds. This mofo is getting heavy.
Old 05-11-2010, 09:45 PM
malteserunner's Avatar
I think tc means you should cut the ends at a 45*, like you did on the corners. Just so the blunt face of the tube doesn't hang up on the trail.
Lookin' good so far. Keep it up.
Old 05-11-2010, 10:03 PM
peow130's Avatar
Well to bend the tube you could do it the old fashioned way..
Cut some relief cuts in it in small angles then bend it and weld it all back together..
Old 05-11-2010, 10:14 PM
algranger's Avatar
Looks great man. Good work so far can't wait to see the finished product.
Nothin like the feeling you get from fabbin up your own crap just how you like it
Old 05-11-2010, 10:15 PM
scuba's Avatar
Just like I have it drawn up in this picture ?
Thanks for the compliments
Old 05-11-2010, 10:17 PM
peow130's Avatar
Oooo yeah i forgot to say this in the other post. I think you should bring in the side protectors a few inches..
It looks like if you were to go up against a tree or something that your bumper would get you hung up on the tree or rock or whatever.
Make it hug the body a bit, kinda like a set of sliders.
Plus there wont be as much leverage against the main body of the bumper.
Old 05-11-2010, 10:19 PM
scuba's Avatar
Thanks buddy
Yea I've spent around 25-30 hours on it so far. It's a lot of work, but I've only got 120 bucks into it. If I went to a fabber I'd be paying 4-600 bucks.. If I can do it myself why not.
A couple people have already asked me why not but one....
Old 05-11-2010, 11:01 PM
Exactly....like in the drawing.
Old 05-12-2010, 02:23 PM
ehhehe x2! I got mine a pawn shop!
Old 05-12-2010, 04:36 PM
scuba's Avatar
Some fullish body pictures of how it sits right now. Didn't get any work done on it today and finals are next week. So I have no clue when I'll make more progress on it.
Quick Reply: ScubaFab Tacoma rear bumper
