Dana 60's for SAS
#41
No, those shock mounts are well secured. They needed to be that low to keep the shock from bottoming out. I may however move them once I weld the blocks on the perches. The butt's a little saggy...
I don't drive it daily as I work from home. I did drive it to the trail last weekend. No vibration issues at all! The only problem is that the splines on the front driveline are worn and make a little noise. To save unnecessary wear and tear, I pulled the driveline off at the diff and hung it up for the trip.
My truck was gutless with 29s! I should just sell 4th and 5th gear. They'll never get used! A new motor is in the works as I have a bad rod knock as it is. I'll be going either with the 3.4L Toy motor or the 4.3 Chevy.
You're better off with your pickup. Less body to damage...
#42
Thought you might want to see some finished pics.
I'm still having a few problems with the steering up front - mostly the infamous death wobble. I don't have the alignment completely tweaked yet and the RAM assist is not installed yet. I changed the ARB blue lines to the yellow coiled standard air lines.
I have to block up the rear a couple inches to get the truck level. Right now it still sags a bit in the butt.
Despite significant trimming of the rear wheel wells, I still rub, but after I get the rear up a little and bump stop it, I'll this everything will fit OK.
Direct from the rear. http://209.20.253.189/ramp1.jpg
Left side view. http://209.20.253.189/ramp2.jpg
Front view. http://209.20.253.189/ramp3.jpg
Left front bump stop. http://209.20.253.189/ramp4.jpg
Left corner view. http://209.20.253.189/ramp5.jpg
Left rear All Pro Johnny joint. http://209.20.253.189/ramp6.jpg
Right rear compressed spring. http://209.20.253.189/ramp7.jpg
Right front close up. http://209.20.253.189/ramp8.jpg
Right rear close up. http://209.20.253.189/ramp9.jpg
Right side view. http://209.20.253.189/ramp10.jpg
JookUpVandetti
09-30-2015 08:58 AM
myotherrideisayoshi
09-29-2015 05:41 AM
Toys4parts
09-26-2015 01:56 PM
