bent torsion rod mount
Old 06-26-2006, 07:21 PM
vanzam's Avatar
My suspension was sinking, it took a bit of messing around and I finally found the source, where the torsion rod bolt pulls the torsion lever down, the metal on the frame is bending inwards, causing less torsion, causing a sinking suspension. My rig is set up for baja with TC in front, so it see a fair bit of abuse. Has anyone found a good mod to make this connection stronger?
Old 06-26-2006, 08:21 PM
snap-on's Avatar
sweet mary you must bash on it hard!
good luck with that one.... only think i could sugest is more material on the frame and connecting the 2 sides together with a brace of some sort.
Old 06-27-2006, 05:48 AM
AH64ID's Avatar
Sas..
Old 06-27-2006, 07:10 AM
seaflea's Avatar
Like Snap-on said. more welds. Iwould think a couple of gussets would work wonders for it.
While you are at it, post up some pics of this. I am curious to see where it is coming apart.
Old 06-27-2006, 07:26 AM
snap-on's Avatar
Originally Posted by AH64ID
Sas..
ummmm if your tweeking the frame from Desert running youll grenade a front solid axle in like 20 min. WAYYYYYY to much unsprung weight.
Old 06-27-2006, 07:57 AM
AH64ID's Avatar
Yeah....
Old 06-27-2006, 08:25 AM
vanzam's Avatar
I have ifs in the front end with a 12" chaos system. So far ive only busted one front axle, and it was because i landed with my wheel cranked to avoid a drop off. And, i suspect my suspension has been limited because of the bent torsion adjuster connection. Ill get some pics up soon, its pretty cool how messed up it is...
In case your interested, im about to put a lexus 1uzfe v8 under the hood. Should allow me to break even more stuff!!
Old 06-27-2006, 08:28 AM
vanzam's Avatar
Yes, metal gussets. I just made some with 1/4 plate steel. They will work for a while, but the domed washer under the bolt head will not seat properly. I am going to cut the bracket off, reweld the original seat for the bolt head and reinforce it with plate steel. Should be bomber then.
andrewtexas123
07-06-2016 01:49 AM
89fourrunner
02-17-2016 06:52 AM
Steven.m.paulk
08-16-2015 04:52 AM
coffey50
07-28-2015 10:55 AM
yourrealdad
07-21-2015 11:13 AM
Quick Reply: bent torsion rod mount
