My 2004 Taco - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck (No one can answer you in this section) > Tacomas
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-03-2006, 11:14 PM   #1 (permalink)
blown4runner96's Avatar
Cool My 2004 Taco
Ok so I got rid of the 4Runner and acquired a 2004 Tacoma...
*6" Fabtech IFS lift
*2" daystar spacers (8" of lift total)
*Total Chaos upper control arms
*35 mudders with some way to bling wheels
*Demello rock sliders and rear bumper
*CBI front bumper
*other mods
Please abide by the administration's rules and DO NOT post in this thread.
__________________
03 Taco with 37s and stuff
Quote:
Originally Posted by lee View Post
i have problems with the nat ttora board, and they stem from your friends actions, and the fact that the other girl who needs attention is still allowed to wheel with ttora for some reason i do not understand :bang:
"Arguing on the internet is like running in the special olympics... Even if you win you're still retarded"
blown4runner96 is offline
Old 04-19-2007, 10:29 PM   #2 (permalink)
Smile the new 03 Taco...
*CBI front bumper
*Chevy leaf springs in rear with Rough Stuff U-Bolt flip kit and spring relocation hardware
*ARB Safari snorkel
*other mods
stock:
after:
__________________
Old 04-19-2007, 10:29 PM   #3 (permalink)
Talking weeeeee! My :other: SFA truck
__________________
Old 05-20-2008, 03:23 PM   #4 (permalink)
Lightbulb My Solid Axe Swap
We managed to get everything completed in one day...
I have to give big props to AJ at Bent Up in Sac. Had it not been for his knowledge, skills and ability to get into contact with people for last minute emergency parts the truck would still be torn apart.
Most of the swap itself went smooth. Hit a hiccup when we realized that we needed spacers for the steering arms. I have to give it to Parts Mike for lending his availability on Sat after hours so we could pick up the part. Had it not been for AJ getting a hold of Mike and Mike being available we would have never finished, at best it would be the next day on stock low steer knuckles. Then we had another issue with a rather large machining defect in the right side caliper. AJ managed to shave off enough of the surface so the brake line would seat properly to the caliper. In addition, he was able to fabricate some small things I needed and also my shock hoops. Also, thanks to his neighbor a few shops over, Dan at Ruff Stuff, we were able to pick up a set of spacers for the rear shackels.
It ended up being all the little stuff that would of ed us, had the swap been done elsewhere. I can't thank AJ at Bent Up enough for getting everything up and running in one full day! So the swap is done, the truck is up and running and now its just the little stuff to take care of and further tweeking after some trail runs!
All of the pics are here: SAS at Bent Up
Before:
After:
Here is my parts list for my D44 leaf sprung swap:
D44 AXLE BUILD UP:
  • 1983 WAGGY D44 AXLE, SEALS, BEARINGS, CALIPERS, ROTORS [$525.00]
  • GEAR INSTALL (GEAR WORKS: SAN LEANDRO) [$350.00]
  • ARB AIR LOCKER - RD116 [$680.00]
  • MASTER INSTALL KIT - YK D44 [$75.00]
  • YUKON 5:38 GEARS - YGD44538 [$190.99]
  • YUKON CHROMOLY AXLE SHAFT KIT - YA W24138 [$402.00]
  • CTM U-JOINTS (2) - 5-297x [$358.00]
  • WARN MANUAL HUBS - 20990 [$80.00]
  • RIDDLER DIFF COVER [$99.95]
  • HI ANGLE DRIVELINE DANA 44 TO TOYOTA DRIVESHAFT ADAPTOR [$100.00]
SWAP PARTS:
  • RANCHO 44044 SPRINGS (2) [$300.00]
  • BILSTEIN 7100 SERIES SHOCKS - AK7114SB04 [$358.00]
  • T100 OIL PAN - 12101-65030 [$80.00]
  • T100 OIL PICK UP TUBE - 15104-62060/GASKET - 15147-62020 [$40.00]
  • T100 OIL DIPSTICK - 15301-62060 [$15.56]
  • T100 OIL DIPSTICK TUBE - 11452-62060
  • T100 OIL DIPSTICK TUBE - 11452-62060 [$23.65]
  • T00 OIL DIPSTICK TUBE UNION - 90405-10033 [$7.58]
  • BENT UP SHOCK HOOPS
  • 20FT 1/4 PLATE STEEL [$60.00]
  • RUFF STUFF SPRING PAD [$29.00]
  • RUFF STUFF U-BOLTS AND PLATE [$65.00]
STEERING COMPONENTS:
  • PARTS MIKE TIE ROD/DRAG LINK ASSEMBLY - 1PM-TRDA100 [$269.00]
  • PARTS MIKE HIGH STEER ARMS/KNUCKLE KIT - 1SP1001KK [$699.00]
  • PARTS MIKE STEERING ARM SPACER [$107.00]
  • MARLIN CRAWLER STEERING STABILIZER - MC-13548 [$79.00]
  • MARLIN CRAWLER STEERING BOX - MC-13551 [$299.99]
  • PARTS MIKE 3/4 LESS DROP PITMAN ARM [$80.00]
  • AN TO METRIC ADAPTER FITTING - EAR 9919DF JERL (2) [$24.00]
  • P/S HOSE END - EAR 134606ERL [$19.00]
  • P/S HOSE END - EAR 139106ERL [$18.00]
  • P/S HOSE - EAR-131006ERL [$69.00]
  • TRANNY COOLER FOR STEERING LINES - MOR-41200 [$72.88]
  • BORGESON STEERING SHAFT [$225.00]
MISC/OTHER PARTS:
  • ARB AIR COMPRESSOR - RDCKA-12 [$189.00]
  • GOODYEAR MT/R 37/12.5R15 (4) [$750.00]
  • 15X8 W/2.5" BACKSPACING STEEL WHEELS W/CUSTOM ROCK RINGS [$350.00]
  • YUKON 5:29 GEARS (TOYOTA) - YGTV6529 [$159.99]
  • GEAR INSTALL (GEAR WORKS: SAN LEANDRO) [$200.00]
  • JT'S SOLID PINION SPACER W/SHIMS (SK CSTV6) [$32.95]
  • TOYOTA E-LOCKER MASTER INSTALL KIT [$169.99]
TOTAL: $7,798.90
The rear end suspension was completed well before the swap using 63" Chevys with an AAL, Bilsteins, Ruff Stuff shocks relocation components and modifying the shackles from the Toyota leafs.
There are still some things that need to be completed after the shakedown run. And some of the little things are not listed, but then again those are parts specific to your swap.
COMPANIES I RECOMMEND DOING BUSINESS WITH:
Went out for the shakedown run Sun, the truck worked great!
All of the those pics are here: Shakedown run: Hollister Hills SVRA
Got the wheels and tires mounted last night.
Yea... nice 37s with no more chrome wheels
Took the rig out on its first real run to truly put all the fabrication to the test. I couldn't of been happier abusing my junk. Everything held together, broke nothing and running 37s is truly cheating on the Rubicon!
Again big props to Bent Up, my future ex husband and all of my truly obnoxious friends!
__________________
Tags
20012004, 2004, 44044, arm, chaos, custom, dipstick, fabrication, oil, pan, spring, swap, t00, taco, tacoma, total, toyota, w24138, ya
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1996 LC wheels on a 2001-2004 Taco ARB1977 95.5-2004 Tacomas & 96-2002 4Runners 5 02-25-2007 01:02 PM
Lions Back Carnage - 2004 Taco Lysmachia Trip-Trail Reports & Photos 89 12-19-2006 11:21 PM
2004 Trd Double Cab Taco blove0007 The Classifieds GraveYard 1 04-07-2006 09:55 AM
Borla exhaust for 2004 Taco... question mummer43 95.5-2004 Tacomas & 96-2002 4Runners 1 11-26-2003 07:50 AM
2009 InternetBrands, Inc.
