YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-25-2008, 02:35 PM   #1 (permalink)
High Water Drifter's Avatar
Warn winch questions
found a good deal on a used warn 9000 premium series. my question is does the clutch handle/ right side of winch able to rotate? This winch i'm looking at has the clutch handle facing front wards, so that it is in the same position as mounting hardware. He had a bumper that had a hole in the front for the clutch handle. Can i loosen hex screws and rotate handle/winch end upwards for my TJM 17?
__________________
97 4runner LTD, rear locker, SS# 7.1, TJM T-17, Bent Up sliders, sport hood, Jaos spoiler, True Flow intake/filter, magnaflow exhaust, Nitto T/G 285's, and some other mods...
99 tacoma sr5 xtra cab 2.4L 2wd (gas saver!)
90 4runner 4wd w/ some mods. (sold)
97 tacoma 2wd (sold)
"ya know, they've done studies ....60% of the time it works every time."
"the beatings will continue until morale improves"
High Water Drifter is offline
Sponsored Links
To remove this ad, register today!
Old 05-25-2008, 03:34 PM   #2 (permalink)
Nevermind, looks like i found my answer...thanks for looking.
__________________
Old 05-25-2008, 05:20 PM   #3 (permalink)
Staff
Elvota's Avatar
Don't keep the answer secret... post up so others that find this thread in the future can share the wealth.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 05-25-2008, 07:06 PM   #4 (permalink)
crolison's Avatar
ditto
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns
rear diff breather, 4 hella 500's driving, sliders, wilderness rack
custom bumper
arb locked rear
toytec adjustables, ome 891's, bilstein 5125
manual hubs
broken front and rear swaybars
My Profile
crolison is offline
Old 05-25-2008, 07:39 PM   #5 (permalink)
4rnr's Avatar
Unless Ive understood something he wants to move the handle from its current location buy rotating that assembly of the winch (the planetarys are on that side IIRC) and the housing can be rotated and the bolt pattern works at all 360* positions. rotating the housind/planetarys/handle forward or backward...
Unless I missed something...
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, custom snorkle, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Electronic shifters by AWshifting, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 05-25-2008, 08:04 PM   #6 (permalink)
Staff
Elvota's Avatar
Quote:
You only missed his answer ...
... but I am guessing you are on the right track.
__________________
Elvota is offline
Old 05-25-2008, 08:36 PM   #7 (permalink)
4rnr's Avatar
I was guessing his answer to try and help some of the people inquiring incase he never came and posted up.
oh and....
__________________
poop
4rnr is offline
Old 05-26-2008, 05:56 AM   #8 (permalink)
dirtoyboy's Avatar
Yes you can clock the clutch levers on 9000s
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Used 8k lb Warn Winch for $200 navyredneck Offroad Tech 13 01-18-2007 06:30 PM
Warn has a new Winch ADH8796 Offroad Tech 9 10-25-2006 03:57 PM
WARN Winch Problems Ranski Offroad Tech 1 03-19-2004 05:15 PM
warn winch goatboy22382 Offroad Tech 3 05-19-2003 04:34 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
