| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
torque used on spindle nut?
#2 (permalink) |
Staff
yep... the pinion depth is off now... save your self the time and money, pull it ALL apart and get your gears reset by a professional.. if i am not mistaken you'll need a master setup kit. while you have it torn apart, put on a triple drill flange from TG (or me) so this issue doesnt happen again. if you dont do it right now and just "guess where it should be" it'll most likely blow up on you and you'll be doing it all over again anyways.. this time you'll be buying new ring and pinion set while your at it.
and for the record its your pinion nut that you too off.
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) Last edited by Tofer; 10-22-2009 at 07:12 PM. |
#3 (permalink) |
You'll only need a minor install kit - the difference is the master kit includes all the bearings in addition to the seals, crush sleeve, etc.
Search "solid spacer" to find out how to build the diff so you don't have to worry about it in the future.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#4 (permalink) |
Well this axle was rebuilt, but I don't know if it has a crush sleave or a soild spacer, I did a search and it came up with three threads. I did some reading on it, and one person says torque it to 52, then on another it says 90. is there a way to see with out pulling off the 3rd to see if I have this spacer, its locked, and has 5.29's I don't know the guy who I bought them from so...
| Tags |
| 2004, civic, nut, rear, spindle, toyota |
